Wiring in Light on the back
muddhogg
Kubota L2501DT, Ford 3910
May 20, 2018
95
55
GA
I know 0 about wiring in lights. I purchased an LED light off of Amazon, this one. And I also purchased this wiring kit. I'm only mounting one of the lights on the back. I see there are some connection under the left fender (L2501dt). Where do I even begin? I was hoping I could just make a simple connection under that fender without going to the battery. Any suggestions?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,156
1,558
Western MT
It's a switchable relatively low power fused plug at 10 amps. You can hook a low amperage light to that, but it would be better to use that connection for your relay and run your power directly to the battery. The link you have shows that you have a relay in the wiring kit. This approach will allow you to use a more powerful light that the fused outlet.
Probably someone has a wiring diagram. I don't.
2,166
I would follow what Jim mentioned - run your own power to the battery, everything separate from OEM wiring using a relay provided.
i7win7
Feb 21, 2020
3,224
3,736
Central, IL
18w is 1.5 amps, something this simple would work
If you want maximum versatility
Fordtech86
L3200
Aug 7, 2018
4,788
5,623
Pineville,LA
You wouldn’t have to go all the way to the battery to get your constant power for the load side of the relay, you can just go to the terminal on the starter where the battery cable attaches.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
398
120
Glendale, Rhode Island
Hello Mudhog and welcome amongst us! My B-2650 has a wire connector for a two wire connector under the rear fender, as well as a plug to plug in a "cigarette lighter" plug on the right side of the driver seat. The problem with both of these, is that although you could use them to power lights, you could not power too "big" a light bar. The fuses protecting these are 10 AMP. You have a 12 Volt battery. So the lights can be 120 Watts max. The best way to power up additional light is a straight shot to the battery (or someplace getting full current ). Use the right gauge wire through a fused relay, and "let there be light". The last concern is the output of the alternator (or dynamo). If it puts out enough "power" you are good to go!
Roadworthy
L2501 HST
Aug 17, 2019
1,649
525
Benton City, WA
You can probably go directly to the connector under the rear fender for your lights. It would be better to measure the current draw first as this is a low power circuit fused at ten amps. The connector under the fender is on whenever the key is turned on so you may want to add a switch into the circuit. Adding a relay would probably be a better way to go but this is the circuit designated for a work light.
muddhogg
May 20, 2018
95
55
GA
Thanks! What kind of connector do I need? It looks like there is a connection there just waiting to be plugged in.
UpNorthMI
May 12, 2020
850
564
Up North, MI
I have rear work light that the dealer fitted to my L series, it is connected directly to the feed wires under the rear left fender, someone above says it is a 10 Amp circuit, take a look at how many watts your light bar needs, I see a lot that are under 60W. If it was under 60W / 75W I would use the existing connection, if it's over this I would suggest to install the wiring kit / relay that you have.
Edit: - I see the lights are 18W each, use the existing wires - No brainer. If mounting on rops use a bracket. DO NOT DRILL ROPS.
Good luck getting it all to work out.
muddhogg
May 20, 2018
95
55
GA
I'm only using one of those small lights, so it should be fine. Is there a connector that I can wire to the light that will then plug into this connector under the tractor?
UpNorthMI
May 12, 2020
850
564
Up North, MI
I'd use heat shrink butt connectors and just remove the ones on the tractor. Alternatively buy matching connectors from your local automotive store. I purchased a couple of $10 connector kits on Amazon, it's amazing how often I go back to those kits.
I need to shoot more critters to stop them chewing my trailer wiring!!!
muddhogg
May 20, 2018
95
55
GA
So your saying just cut the connector off and wire directly to it, correct?
UpNorthMI
May 12, 2020
850
564
Up North, MI
Have not seen that connector block before. I suggest either Check the output voltage with a meter or insert the wires to your light, it should work with tractor running.
remove connector block then use heat shield butt joints or other automotive type connectors such as spade or bullet ends.
ctfjr
L3800HST
Dec 7, 2009
1,705
1,919
central ct
I'll throw my $.02 in here. If you wire it directly to the connector under the rear fender your light will be on whenever the key is in the on position. If that's not an issue . . . If you would rather have a switch to turn it on and off its easy enough to wire one in series with one of the legs going to the light. Of course you will need to mount the switch somewhere. I am in the process of putting an electric motor on my snowblower for chute rotation and mounted my switch here:
I just notched out the slot in my unused draft control space.
btw it has been my experience that those led lights are not nearly the wattage that they claim to be. I would be amazed if that light you bought draws an amp or more (less than 12 watts).
I mounted a relay and fuse block on the inside of my left fender. The relay coil is energized by that connector others have referenced above. The relay contacts then send power from the battery to feed the fuse block. I have 6 fused circuits now available in the rear.
muddhogg
May 20, 2018
95
55
GA
I got it all working! Just need to tidy it up this weekend! Thanks for all the help here!
