Will a B6000 steering box fit B7000?
skikir
B7000
Mar 31, 2010
12
Eugene, Oregon
Will a B6000 steering box fit B7000? My steering box on my B7000 is giving me some cracking sounds witch seems to be a symptom of a bad box. I may have a line of B6000 parts.
4,858
If I remember right they are not even close to the same.
It's also not even close to the more common B7100 either.
Post some picture and dimensions of the box and collum and I'll see if I can dig up anything that might help ya out.
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
I tried to rebuild by B7000 box the parts were totally wrong eve though they were listed as the B7000. I found a good B7100 steering box with the pitman arm and steering wheel. It fit right up. AFTER i cut off the bracket for the dash panel and re welded it at the right height. the nut on the pitman arm link to the left front steering knuckle is a little on the tight side to get on and it rides very close to the frame of the tractor but does not hit the frame works great Joe dash.jpg
