RMS
Sep 26, 2021
323
715
Buckfield Maine
Changed the fluids in both gear boxes on the snow blower yesterday. You can tell which side is used the hardest. The oil in the auger gearbox was definitely used harder and seemed to be slightly milky, probably from being jammed into the snow the whole time it's in use. The oil in the gearbox on the backside of the blower looked like it just came out of the bottle.
I also greased all of the zerks on the blower and subframe so it's ready to go whenever needed. I hate to crawl around on the cold floor greasing this stuff at the last minute before a storm hits.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
276
520
Moseley, VA
Hit a milestone the other morning, time to buy some UDT2 ;)
Reactions: 8 users
BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Mar 20, 2016
97
189
Evansville, IN, USA
I am at 975hrs on my GL3130 that I bought in 2007 with 125hrs on it. It was a repo and I got an insanely good deal on it.
Averaging roughly 450 hours per year just using on my 14 acres. Flawless machine so far!
Shawn T. W
Dec 9, 2024
893
1,617
SW Missouri Ozarks
Placed an order for a second set of rear remotes, and 2 sets of the 103 Lb steel wheel weights and mounting hardware for my L5030 ... They are backordered, but still available for my 21 year old tractor!
Should be in the middle of December ...
g_man
Feb 3, 2023
418
2,008
NE Vermont
We had a maple that got ravaged by the wind last summer.
So yesterday I took it down a piece at a time and will turn it into firewood.
I put the camera out thinking that some may be interested in seeing a video - about 20 minutes.
gg
Reactions: 13 users
In Utopia
L175 FEL
Apr 21, 2013
674
205
Utopia,Tx/Pasadena,TX
gg
Great video, thanks for posting. You took a nasty mess and turned it into a safe take down.
If you don't mind me asking, how old are you?
g_man
Feb 3, 2023
418
2,008
NE Vermont
Thanks very much for the comment. Just turned 80 a couple weeks ago - not as easy as it used to be.
gg
Reactions: 9 users
forky
L2501 HST 4X4 8N BB 1266 Box Blade RTA 1258 Tiller QH10 48" pallet fork s
Feb 23, 2021
353
397
Wisconsin
gg
I agree with a nice job well done. It's not as easy when one gets older, but the time spent in the woods feels so much more like a blessing and never taken for granted. Love your winch and wish I would have bought one years ago.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,754
4,661
PEI Canada
Filled in the hole where our fire pit used to be.
Reactions: 8 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,003
2,372
Western MT
I worked on a big part of the community road again today. I took off the rear blade and put on the grader/scraper. There were a lot of potholes, so I put the scarifiers at max depth. That's very unusual for me.
I don't usually even use the scarifiers. I lost a pin which dropped the center scarifier. I found the pin and the scarifier which was good. I have no idea how the cotter pin came out.
The question I need to figure out is why some cotter pins are so much harder/stronger than others. I find it pretty strange considering they look virtually identical.
I'll make more passes this week weather permitting.
Spam Bot
Windows Computer
Aug 3, 2024
215
163
Austin, Minnesota/Key West FL
Not today, but finally got some more use out of my backhoe digging the service to my new garage a few months ago.
I don't know where you live, but yesterday I dug a similar trench and only got half as far as you did, but I pulled out rocks with every scoopful of dirt. Some of the rocks are so big that I had to pull them up and push them aside because they are too large to fit in the loader bucket. I have enough rocks in the rock pile to build a 30' rock wall, if only I knew how.
g_man
Feb 3, 2023
418
2,008
NE Vermont
I have most of that tree I took down the other day in the wood yard now. All that's left in the woods is the stump I cut off and some limb wood. The big pieces from the butt were only 8-1/2 feet long so I got them with the grapple. These are the leaders that were spread around. I winched them in to make a hitch.
On the trail out.
gg
Reactions: 12 users
RMS
Sep 26, 2021
323
715
Buckfield Maine
Nothing as near dramatic as some of these folks doing "big" tree work, but I cut an old crab apple tree down yesterday and used the grapple to haul it away. I also used the mini-ex to dib the stump out.
It sure is nice to have the tools to make jobs easier!
Reactions: 10 users
Old_Paint
Dec 5, 2020
2,057
2,364
AL
Did my 600 hour service. No photos, mostly because I don’t do selfiies while I work. I had a large box that I flattened and laid on the floor, mostly because I know how messy I am as a mechanic. Changed engine oil/filter, changed fuel filter, cleaned the air filter, and changed the hydraulic suction filter.
I’ve read about using a shop vac to swap the suction filter without draining the hydraulic oil, but today was the first time I tried it. Turns out, my shop vac might just be a little too large (16 gallon 5HP Rigid) for this application. It tried really hard to suck my whole tractor through the little (3 inch) hose. All was still good until I loosened the filter. By the time I could get to it and turn it off, the vacuum was strong enough to foam the hydraulic oil and was sucking it into the hose. Spinning the filter back on stopped the oil, but too late for the mess it made in the hoses. Fortunately, I had some trepidation about this very event and had put a cyclone for dust separation in the line between the vac and the tractor. Captured about a quart before I got it shut off. I had used a clear section of dishwasher hose for the size of the fill hole, which was fortuitous to be able to see the oil going in the hose. So I started poking holes in the hose near the tractor end and finally figured the dipstick would also vent some of the vacuum. Only just enough to stop it from sucking oil out of the tranny. I spun the old filter off and the new one on which stopped the foaming of the oil. Still a lot quicker than draining 6 gallons of expensive UDT-2 and trying to keep it clean to put back in. The app says both filters, but the book says just the suction filter, so I went by the book. I pulled enough oil out of the transmission to see how much‘wear and tear’ I put on it this summer while I was mowing some large and very overgrown pastures. The changes at 200 and 400 hours made me wonder why I was replacing the oil. I’m thinking I might just do it again at 700 hours.
One other little side note is that I make my own floor sweep for my shop. When I change the fuel filter, I put a bucket of sawdust under it to catch the drips and drain the filter cover into it as well. Diesel in sawdust is great for controlling dust on a concrete shop floor and since it’s absorbed into the sawdust, it doesn’t leave any residue on the floor. It also helps with keeping grease and oil cleaned up that would otherwise make the floor slicker than greased monkey snot on a boiled egg. It gives the shop a manly he-shed aroma as well. I don’t worry much about it being a fire hazard because it’s pretty hard to set diesel on fire when it isn’t compressed. I still remember the smell of the oiled wood floors in school and the smell on Monday morning after the janitor use sweeping compound. Nothing was ever dusty in that schools when I was a kid despite the amount of traffic in the halls.
Reactions: 7 users
mdhughes
L3901DT
Dec 10, 2014
1,486
1,604
Ste Geneveive county, MO
Yesterday I used the L3901DT with pallet forks to move a stack of landscaping timbers.
Then I worked with the box blade to contour the ground next to the new lean-to I build a couple of weeks ago. My wife and I had stacked the bundle of landscaping timbers next to the lean-to so they would be close while I built the retaining wall between the old lean-to and the new one. So I wasn't able to do any dirt work next to the lean-to and we had a good rain causing the ground inside the new lean-to to get really muddy. I need to put a section of gutter on the old lean-to to catch the water coming off the roof and discharge it below the new lean-to. The new lean-to isn't the full length of the shed and the old lean-to.
Reactions: 6 users
RMS
Sep 26, 2021
323
715
Buckfield Maine
More end of season work yesterday. I removed the deck from my zero turn and cleaned it out, painted the bare spots and sharpened the blades.
I was debating on lifting the front end and putting it on jack stands to do the work, but it turned out it was easier (especially on my back) to just remove the deck and then flip it up to do the work rather than lay on the ground to do the work.
Reactions: 9 users
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
899
1,699
Baranduda, Victoria, Australia
After finishing getting the hydraulic steering put together today (and it worked), my wife and I moved a few things out of the shed to make way for the big new (old) lathe and new (old) mill drill that we'll be collecting tomorrow.
I've heard that there's still people around that don't have one of these little tractor things, but surely there can't be many.
Reactions: 12 users
