g_man
Feb 3, 2023
379
1,773
NE Vermont
A few weeks ago we had a real gully washer. It's a little hard to see with all the mottled shade but it washed out some minor ruts in a couple down hill spots in our road - like this one.
First time I used the grader this year.
I made about 6 passes total, all up hill. Filled in the washes and remixed the gravel.
and then packed it with my one-ton
gg
Reactions: 13 users
Old_Paint
Dec 5, 2020
2,019
2,267
AL
A long-time friend of mine has a home repair/remodeling business about 40 miles south of me. I'm retired and doing little more than teaching my chickens to play piano and do trigonometry, so I help him out on occasion for little more than boredom relief as pay. He introduced me to a retired doctor, who impressed the heck out of me. She's 94, still does ballet, can do a standing split, cuts her own grass, and tends at least 20 farm animals that she uses in up to 3 magic shows every year. But recently, she's had triple hernia surgery (I'm guessing from over exertion) and a few years ago fired the guy she had managing her pastures on a 32 acre property. As you might guess, they've grown up from neglect and are in dire need of management, so I sorta volunteered one day a week to get them caught back up.
The first field was nearly 6 acres and is a mix of just about any kind of grass you can think of, and a whole lot of cross-pollinated varieties that are THICK, especially in the bottoms of the hilly land. This has been my first experience with a flail mower in grass, and I'm still wondering if I'm doing it wrong. What I found is that tall grass and hammer flails don't particularly like each other. The grass tends to build up on the hammers and start pushing the grass over rather than cutting it. I have the option to switch to Y blades (the mower came with both), but there's also some 2-3 year old sapling growth scattered about that the hammers will do a much better job on. The problem is, it's a very time-consuming job to switch between them, so swapping blades back and forth is not really an option. I need the hammers for major cleanup, but think the Y blades will serve better in 'pasture grass' once I get it knocked down.
What I found works best is to make a half-swath pass in one direction, turn around and go right back where I came from cutting a half swath in the opposite direction. It's a very slow way to cut, but I'd need a much bigger tractor and mower to do it any other way. This also seems to clean it up a lot better than simply going the same direction multiple times. Basically, it results in the field being cut twice by the time I finish with it. It's a slow go, but not a bad finish for overgrown fields. There's plenty dewberry and black berry briars to go with the thick grass, and of course, near the fence, mower beware. The fence rows are like a box of chocolates because the previous guy that mowed them for her just kept getting farther and farther from the fence because he couldn't be bothered cutting the limbs back and cleaning up as he went. I didn't make a full lap before I found some heavy gauge electric fence wire and wrapped about 50 feet around the flail drum. An angle grinder turned out to be my best friend for a remedy because the wire was fairly large gauge steel wire with a fiberglass sleeve. Got that cut out, and was nearly done with the field (about 10 hours later) when I found something equally evil. Apparently, someone that the owner let board a couple horses used large round bales to feed them. I really don't think she knew what she needed to know about large round bales and horses. First of all, large bales tend to mold LONG before they're consumed by a couple horses. If the horse owner is lucky, and the horse gets picky, they won't eat it. If they aren't lucky, they find their horse laying on it's side dying. Horses and mold do not mix and hay left in the elements is going to mold. Unavoidable. Secondly, the bales provided were apparently wrapped with some kind of nylon or polyethylene mesh, which the horse owner or feed supplier didn't bother to remove and get out of the pasture. I'll give you 3 guesses what I found when I hit a large patch of deep Bermuda grass, and the first two don't count. I just thought the electric fence wire was bad. It took a while to cut that mess out of the mower because it wrapped very tight. Making bad worse, I made two more laps and found another big ball of the stuff. That's TWO. It was getting late, and we wanted to check out an overgrown road (with pines up to 4 inches in diameter growing in it) so I cut my way over to that had a go at what I thought I could chew up with the flail, then went back and loaded up to come home. Next morning, there's a THIRD hairball under my mower and I ain't happy. IMO, ANYONE that uses synthetic non-biodegradable mesh to bale with should be beaten with a stick. A big stick. Maybe a stick with "Louisville Slugger" branded in the side of it. That stuff should be outlawed on the planet. It's extremely dangerous for livestock to ingest it, never mind the dangers it poses to any wildlife that gets tangled up in it. The lady that owns it has at least a dozen geese, 4 donkeys, and a horse and no telling how much wildlife roaming the property.
Ennyhoo, I started the second field yesterday which is approximately 12 acres, and my guess is it's gonna take at least 3 days to clean it up again. According to my buddy, "It's not quite as thick". WRONG. Just as thick, if not thicker in the bottoms with a mix of Bahia, Bermuda, Johnson and even Centipede grasses. Tree limbs were hanging over the fence at least 30 feet out from the fence. And what else do I see? At least 5 spots where large round bales have been put out for feed. That's just the ones I could see, and I'm paranoid about how many have grown over. I cut until I got close to the first one, and then I used the grapple to scrape up all the old hay and the giant hairball of wrapping that was very well hidden in the grass. I also created an enormous brush pile from all the stuff we cut off the fence rows. The little old lady's horse started following us around, and while I was trying to figure out a repair in a corner, the horse nuzzled me and knocked me down. Just being friendly and curious, though, completely unintentional. The horse acts like a very large lap dog wanting attention. We got about 2/3 of the fence line cleared enough to see the fence from the inside and maybe about 1/3 of the field cut yesterday.
It's been a long time since I've spent those kinds of hours on a tractor and had completely forgotten how therapeutic it can be. I was tired, but relaxed and felt pretty good about what I was doing. Not doing it for the money so much as just trying to give back a little of what life has given me.
For now, I'm going down every Monday until I get it all cut down the first time, and will try to get her to let me cut it again before it gets so wild so that maybe it will improve the quality of the pastures for her animals as well as make the place look a lot better. It was a beautiful place at one time, but gonna take some effort to restore it. She has an old L3130 with a 5 foot RC behind it, but there's places that I prefer my LX2610 with 4WD and loaded tires along with the grapple for some of the clean up work. I also like the hydrostatic transmission that lets me slow down the travel speed a bit when I get in the really thick stuff. I nearly stalled the tractor with the mower twice in the thicker places. Her old L3130 is a manual transmission, and I'd wager the blades on the RC haven't been sharpened in at least 10 years. Needless to say, I don't think it would do much better than my little 4 foot flail as far as getting it cut down any faster, and the wear and tear on the clutch would be miserable. I can swap ends pretty quickly on the LX with no shifting. I just cut some headland along the fence rows, and a quick 3 point turn gets me on my way back to where I came from. Some places I can turn around without backing up at all because the flail is so short and I don't have to worry about taking out the fence with it.
Reactions: 9 users
Bmyers
May 27, 2019
3,617
4,885
Southern Illinois
I was out mowing this evening and they showed up to spray the field. First time we have ever had drones here spraying.
Reactions: 9 users
DaveFromMi
L3901 RCR1260
Apr 14, 2021
672
711
Indiana
Today I rototilled the patch of ground I mowed and plowed the other day. I borrowed an old 62" Land Pride from the neighbor. It digs down about 8". This is my my first time using a 3 point tiller. I went over it the first time in 1st gear max depth. It would bog the tractor down in 2nd. The 2nd pass, I ran it in 2nd gear. This is the most I've pushed the tractor since I got it. The old tiller does a nice job.
Reactions: 11 users
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
151
275
St. Clair, MO.
...I'm retired and doing little more than teaching my chickens to play piano and do trigonometry, so I help him out on occasion for little more than boredom relief as pay.
If not you, than who? There are so many chickens out there that just peck and scratch on the piano and are totally helpless when it comes to trig. Bless you, sir! (-:
Old_Paint
Dec 5, 2020
2,019
2,267
AL
Yeah, I kinda felt the same way about the piano thing. They don’t have enough toes to be really good at it, but they have very similar handwriting to mine, so I started introducing them to mathematics. Some almost seem to understand it, others are dumb as a box of rocks.
Jsjac
B2650
Feb 13, 2022
244
402
I have been wanting to move my small wood shed for a while. I need to get the 2037 wood under cover soon.
I brought home a load of 3 inch stone in my dump trailer and leveled behind where the shed was.
The shed is on the skids ready to move.
IMG_20260704_110846351_HDR.jpg op IMG_20260704_110846351_HDR.jpg IMG_20260704_110850160_HDR.jpg
Now it is in its new location and all leveled up and ready to be fill with wood
Reactions: 11 users
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
154
299
Mark Twain Forest
Moved road kill ditch deer by the driveway to the back 20.
But first, removed the 3pt 45 gal sprayer. And the electrical connector unwires itself. :mad:
Factory wire crimping was to the Minimum Necessary Crimp for household electronics. The connector contact crimps were geometrically symmetric and pleasing to the eye. But don't hold worth a dead deer's butt out in the field.
Recrimped and assembled with proper 100% full force contact.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,698
4,458
PEI Canada
Mowed my yard and brother in laws. Easy going
Went to the neighbors since his mower is down and it was over a foot tall of moist clover. Made a mess but he was happy.
Reactions: 7 users
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
52
311
53
MN
Just something to sink my teeth into. My weekly skim across the top.
Then one pass up a hill to level the rain wash out, no before photo. Gonna hot this week in the Midwest, probably not much riding.
Reactions: 6 users
Old_Paint
Dec 5, 2020
2,019
2,267
AL
Today kinda started yesterday. The TSC store that the missus works at wrote off one of the Producer’s Pride Guardian chicken coops. Look it up on the TSC website and you’ll see why I built my own coops. But a customer bought the thing and found mold on some of the wood in it and other water damage caused by the fact TSC stores a LOT of merchandise outdoors. They have their rules, whether they make sense or not.
Ennyhoo, I picked it up for 5 cents on the dollar because otherwise it was dumpster fodder. I figured I could use some of it for various boredom projects. So, yesterday, inventory the contents and find it’s missing one part I can easily duplicate, and another is water damaged beyond recovery, but also easily duplicated. So I put the thing together on my driveway
I need another coop like another hole in the head, but I saw the potential for using this to raise the next generation for our flock. It’s way too small for what I would consider for grown birds, but perfect for putting new chicks within a few yards of the main yards. I already have a quarantine pen, which I’m currently using for 3 broody birds to break up the squatters hogging the nests.
I finished the run section today and it was time to relocate it to a spot near the other coops until I can build a foundation for it with crossties. Ya gotta love these little workhorses.
It probably weighs about 400 pounds, but the length makes my clamp on forks on the bucket probably not the best way to lift it, but you’ll notice there’s no ballast on the back of the tractor. Not even the box blade. If there was ever proof that loaded rear tires are the best thing since shirt pockets, this is it.
Edit: I have Bolt-On hooks on top of the bucket backed up by Bolt-On D-Rings under the top lip. The strap is connected to two 1/2” clevis’. I originally had the D-Rings in the bottom of the bucket, but just bolted the backing plates from the hooks and rings to the bottom just to keep track of them and moved the rings to the top of the bucket.
Reactions: 10 users
Old_Paint
Dec 5, 2020
2,019
2,267
AL
After moving the coop, I took the forks off and rolled the compost heaps. Didn’t figure many would be interested in seeing two large heaps of chicken poop, barn lime, garden scraps, wood chips and anything else we can’t feed the girls. Got that done and put the grapple back on for upcoming work on Monday.
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
645
1,860
Vermont
youtube.com
I did some driveway work, the sides really needed to be scraped down to create a crown. I spread out the 22 yards of driveway mix I got delivered. The box blade worked incredibly well.
all the sod I scraped out with the box blade now there’s a good crown going on. I first started by dumping bucket after bucket the new driveway mix down the middle first then spread it out with the blade and started in the sides so there’s a significant crown. Hopefully this will be better than what I had! I got a little too excited and made the driveway wider hahaha
Parked my truck on it to see the crown haha
I’m happy with it, the driveway finally got the love it needed. Now if I had rented a roller that would’ve been icing on the cake but oh well. It packs down pretty quickly.
Reactions: 12 users
Old_Paint
Dec 5, 2020
2,019
2,267
AL
Swapped the hammer blades out for the Y-blades on my flail. Gonna see if they work better in the overgrown pastures I'm mowing. There's not much big brush in it, but a LOT of very thick grass and large weeds that build up on the hammers and stop them from cutting. I'm starting to think a RC might be better than a flail for a recovery operation like this.
3,028
You might be able to raise the flail up off the rear roller so you aren’t cutting as much off. At least that is what I’ve been told that some flail users do. But then you may have too much rough terrain to contend with!
I don’t own a flail so don’t know how much that can effect your tractor stability.
I do know that a rotary cutter will knock down tall grass but it will also leave heavy windrows and the grass will be uneven (not all cut well). So you might not be that happy with a rotary cutter either.
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
168
356
NW Arkansas
Nice work with a BB—only way to learn to use it is to use it. Looks really good.
nerwin
Nov 13, 2024
645
1,860
Vermont
youtube.com
thanks everyone!!
I ended up bringing the tractor down to my grandmothers and reclaiming her driveway after a recent storm washed it out. She can't afford to have it fixed so I did the best I could with what I had. It looks like a new again, tried the crown it but there isn't enough material. All in all, it came out better than expected and she's happy.
My payment? Cookies!
Reactions: 8 users
Bmyers
May 27, 2019
3,617
4,885
Southern Illinois
thanks everyone!!
That is some of the best payments you can get.
S-G-R
Jun 17, 2020
1,698
4,458
PEI Canada
My top and tilt kit came from FiteRite hydraulics this afternoon. Both cylinders and the hoses were very well packaged. I'll get it put on sometime this week.
Reactions: 11 users
