Here is the issue I purchase one of the metal spray foam insulation guns , such as great stuff.
The first can goes on ok and when empty it comes off ok, I then clean the gun with the cleaner.
But when I try and put on the second one the cartridge foam leaks out at the attachment cage. Tried to tighten or loosen the can but no luck.
I know it is something I am doing as I have purchased several guns which work fine with the first canister but not with the second.
Is there a seal that comes off when I remove the first spent can? is there a special tool to tighten the can more?
Any ideas or suggestions would be helpful
