Ok so I have a Lincoln vantage welder with a v1505 I believe e2-bg. It’s 1800rpm. I was not getting fuel coming out of injector pump so i pulled the tank and inspected then inspected rubber lines. Replaced all inline filters. Replaced fuel pump.
Still no fueL out of ip.Found pumps online for 700.00 Seems extremely high. So I pulled the ip out. And took it apart. Had some corrosion Cleaned it all up with wire brush and replaced all the o rings. I reassembled the pump and installed Now I’m getting fuel squirting out of all the ip ports but still no start.
Do I need to time the injection pump? I found the info to set the timing in the manual. I just don’t understand why I would if I never turned the motor over with the pump out.
