Using backhoe to push my L2502
Bryston
9
Am new to tractors, if i push the tractor while digging with backhoe 2-4 feet at time, do i need to but in in Neutral, it is HST . Will it damage anything if I leave it in Medium (M).
Thanks
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
149
267
St. Clair, MO.
Short answer: No.
Heck, I leave the brake on and just lift the rear tires when I push. (-:
Bryston
9
Thanks, I was pushing it with the tires on the ground , rolling it slowly while on medium M. Is this going to damage anything?
Thanks
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
244
615
wisconsin
wont hurt anything long as you put the bucket back down and put the stabilizers down.
Quick
Sep 23, 2021
149
267
St. Clair, MO.
Bless his heart. (-;
hodge
Nov 19, 2010
2,959
531
Love, VA
Does your tractor come to a stop when you take your foot off of the hydro pedal? If it does, there is resistance to rolling. It's an easy maneuver to put it into neutral before moving it with the backhoe. Don't risk damaging your transmission for the sake of a quick flick of the lever.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
184
256
Hardy, VA
Nope. I do it all the time.
10,738
Thanks
Yes you can damage parts leaving the transmission engaged and pushing it.
BX23-S,57 A-C D-14,
6,251
I had a cheater stick on my BX23S, Use it press forward pedal. if you time it just right , engine doesn't die.
Lost the stick in the bush ,so back to using BH.
It's a whole lot easier WHEN you lift the bucket first though........
