Two Issues
Mr.Bentwrench
Kubota B3030 WD45 Ford9N
Apr 20, 2022
Southern IL
Hi guys. I have two issues that I need to address, The tractor is a B3030. The first is that I have managed to shatter the lh door. Is this a pretty straightforward repair, assemble it on sawhorses and then put on tractor? anything special to watch out for? The other is changing the alternator and the A/C belt. Any hidden obstructions that make it difficult? Thought I would run it by some smart fellers first. Thank you.
Hkb82
M7060 can-am defender hd10 gmc at4
Nov 17, 2021
71
65
Bruce peninsula
Don’t own a b3030 but it’s would be a pretty easy job on m7060. Tensioner bearing took about 5 min. I’d maybe have a second set of hands around for the glass work just in case but also should be pretty straight forward.
