J Jsinus New member Equipment L3800 Aug 15, 2021 15 3 3 California Jul 1, 2025 #1 I've a Kubota L3800 HST and need to replace the Sight Glass. Do I need to completely drain the Transmission Hydraulic oil b4 removing the glass ?
J JasonW Well-known member Jan 29, 2015 473 251 63 Al Jul 1, 2025 #2 No not completely. Just drain just below the sight glass. Or if you’re comfortable have a drain pan ready and remove the old sight glass and install the new one. Reactions: 1 user
old and tired Well-known member Equipment L2800 HST; 2005; R4 Dec 8, 2019 1,786 1,139 113 Raleigh, NC / Hillsville, Va ffhill.blogspot.com Jul 1, 2025 #3 You can run it up on a side hill until the oil is below the sight glass, no hill, use a jack to artificially make one!! depending on how low it is, you might be able to use the FEL to raise the front up enough to switch it out... Reactions: 1 users
Flintknapper Well-known member Premium Member Equipment L2350DT May 3, 2022 1,929 2,434 113 Deep East Texas Jul 1, 2025 #4 old and tired said: You can run it up on a side hill until the oil is below the sight glass, no hill, use a jack to artificially make one!! depending on how low it is, you might be able to use the FEL to raise the front up enough to switch it out... Click to expand... ^^^^^ This. I just drove my tractor up a ramp on one side, then replaced the sight glass. Reactions: 1 user
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, B7200DT/B1630, G2160/RCK60, G2460/RCK60 Apr 6, 2021 9,769 5,154 113 Myersville, MD windyridgefarm.us Jul 1, 2025 #5 Reactions: 4 users
