I took the cylinder liner off my tractor because my 3 point arms were staying up. I am going to rebuild the cylinder and the control valve. I cant help but notice the top link bracket has grease fittings in it but the main shaft has pins in each side so it cant move. It has a rod that goes to the control valve. Am I supposed to remove the pins when using the three point. They look permanent. not sure how it moves the sensing rod if it is solid. Thanks in advance for any help
