Too fat/lazy/old to unlock your SSQA?????……..Then follow me ;)
Chanceywd
Mar 26, 2021
837
838
central ny
This cylinder looks like a good fit. I would cut off the base end and extend it.
The eyes look right with maybe a bit longer bolt.
The cylinder I used to make my thumb hydraulic was one of their brand and I have bought several others for angling my back blade etc.
Sorry RWS you got this old brain thinking about this again.
The sad part is I found and ordered a new linear actuator last night on Ebay.
Bill
7,233
Bill
Take your pick. I am sure you can find one that will work right out of the box
Chanceywd
Mar 26, 2021
837
838
central ny
I guess i'm stuck on the 8" stroke being perfect amount needed and by extending the overall length to fit between the linkage bolts. No need to worry about linkage getting stressed because the cylinder reaches its end of stoke both ways.
That is how I made my non weather proof linear actuator work was by extending the ends. The new one I ordered is supposed to be waterproof 8" stroke and I will reuse my hemi ends. The hemi ends come with adjustable right and left hand collars for mounting to fine tune the length.
I know, here bill goes off topic again,
When I made my thumb hydraulic I found an almost perfect cylinder there. It had side ports with the right pin bores and the rod end was a perfect fit at about 1-1/2 wide.
The base end was narrow so I welded a couple shaft collars on and the machined them down for a good fit.
But also to get the cylinder and thumb to tuck up out of the way I welded a plug in the base end hole and re drilled it a fraction of an inch off the original closed length.
For that I could have cut off the BH77 mount and moved that instead. The re boring made sense at the time.
Bill
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
707
820
NE FL
I wouldn't hesitate to buy the cheaper selector valve. BUT, before you make a decision figure out all your port sizes and make sure adaptors are available to connect the hoses. Consider if you will want 90 degree adaptors or straight. Like I said, the cheaper ones come with #10 SAE ports or 1/2" BSPP. You will probably want to adapt to 1/4" JIC if possible. You're probably going to have at least $300 invested in this project if you go hydraulic.
Any hydraulic setup takes hours of figuring out to make sure all the pieces of the puzzle will fit.
This is why the linear actuator makes more sense in my opinion. The one I linked to in post #34 is IP54 which isn't water proof but should be okay if the tractor is stored in a barn. You could probably put it in a piece of PVC pipe to further protect it. It even comes with the directional switch. You just have to figure out where to mount the switch and get a 5 amp power to it.
B2710
MX6000HSTC, KX-040, RTV1100, L3300F
Dec 13, 2011
59
35
NW Tennessee
Here is the linear actuator I picked up to do the same thing on my MX6000, still figuring out the mounting plates... I just do not have the wherewithall to do hydraulics but my bobcat skid steer has hydraulic QC and I like it, not very fast, likely the same speed as the actuator will be...
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,374
995
Minnesota
Here is a better idea. Go get a hooker to take your mind off doing lazy crap! Will build up your confidence that you can do it all day long! :ROFLMAO:
5,312
Thanks all for the advice and the links.
I am going to order the cylinder posted above and the “El Cheapo” 60 dollar diverter…If it craps out I will get a better one….Seems like a small risk in the scheme of things….
Once I get it, I will "fab up" some new handles, or, as I type this I am thinking maybe just modifying the exising ones….still undecided.
However, I know I am going to go the “hydraulic route”
Stay tuned…. 🤞
7,233
However, I know I wam going to go the “hydraulic route”
Stay tuned…. 🤞
I think thats a sound plan. I am confident that diverter will be fine - not much in them that can fail.
Sidekick
Jul 29, 2023
1,248
1,795
N.Y,
This one looks simple to make and get ideas from.
Chanceywd
Mar 26, 2021
837
838
central ny
I thought about that, but I am impressed with the speed and “beefy’ness” of the hydraulic version. (y)
Hey Coach Scissors, can I come over to your hydraulic team? I put together my new waterproof linear actuator and it is painfully slow. I'm trying to do this from my phone which is also painfully slow for me. My internet is down for the second day but it was working for a while last night and in a weak moment I ordered that 1x8 stroke hydraulic cylinder. Bill
Here is the proof of progress, as is said here often , no pictures, it didn't happen.
BX23-S,57 A-C D-14,
6,285
yeah, I tried a linear actuator knowing they are slow, though if you buy $$$$ones they are faster, still slower than getting out and moving the handles though. I did get faster speed by using a 'boost convertor' that converts 12 volts to 30..still not fast enough . Hydraulics are easier to get speed...but $$ for 3rd fnx/plumbing.
Chanceywd
Mar 26, 2021
837
838
central ny
I got that cylinder yesterday. I have an idea to make an extension for it.
The OD for the cylinder is 1-3/8 according to their drawing. I ordered a couple double split shaft collars
My idea is to make the extension mount at the swivel and go past then use a shaft collar and weld to that to keep it in line. This would make it removable and no welding on the cylinder itself.
The other end is going to get one of the hemi ends for fine tuning.
I will post a picture once I start cutting pieces and welding.
Bill
Chanceywd
Mar 26, 2021
837
838
central ny
Bill
Bad news to report on my cylinder choice.
The swivel end is about 1" from edge to bolt center.
The distance on the existing area where I installed the linear actuator with the hemi ends is about 3/4".
So some grinding on the end or the SSQA is going to be required or an adaption of some sort on both ends.
Thought I would make it known before others order this style cylinder.
Going to look at alternative attachment point to the levers to see if I can make the 8" stroke work.
Bill
5,312
Well, I got my cylinder yesterday, but the diverter is still “in route”.
Although, I suppose it don’t matter, cause I had to leave the tractor at the cottage.
My brakes started grinding yesterday, so there was no way I was going to pull anything home…..
The up side to this is that I was able to successfully drive home (about 300 miles) and only hit the brakes once….. by “judicious shifting” practices. ;)
5,312
Bill
Look forward to seeing the progress sir! (y) (y)
Chanceywd
Mar 26, 2021
837
838
central ny
I do all my own auto repair work. I put up a shop 23 years ago with a lift. One of the best investments I ever made was the lift.
My 2006 Silverado 2500hd started making the front brakes shaking back thru the steering trick this spring.
It has about 240k on it and I had done pads and rotors last year. So suspecting calipers I ordered everything including new hoses from Rockauto.
The moral of this story I guess is even though I have a lift I reverted back to my old ways and did it in the driveway, putting the front on jack stands.
I have a lot of things going on with wifes health and figured I might get started and then not get it finished in a day or so and I didn't want it tying up the lift. Wound up being several nice days in the sun!
It was a flashback to the days of crawling under to do all those things in a gravel driveway but I still love wrenching!
Bill
5,312
I couldn’t agree more…. (y) (y) (y) (y)
My garage is pretty tight, and I don’t know if I actually enjoy it or not, but it’s one of those things that ‘mentally’ I can’t yet let other people/mechanics touch my stuff…..I dunno🤷‍♂️
Your location might not work, but I usually use Detroit Axle for most of my “hard parts” (i.e. brakes and suspension)…You can find them on Flea-Bay.
Chanceywd
Mar 26, 2021
837
838
central ny
Made some progress on mounting that cylinder yesterday.
All except what to grind on the rod end.
I will take some couple pictures and post them when I get a minute.
I did find that cylinder eye is 1" thru so I picked up a couple M12-1.25 x 45 bolts so a little more thread is going into the linkage. I could only find 8.8 locally. I think I will try to find a couple heavy grade on line.
My brother lives in Buffalo about 3 and a half hrs away and stopping by today so not much tractor stuff getting done. A little tinkering on our late life crisis cars and a beer or maybe two and lunch!
Mines a 2006 red Miata, his is a 2008 banana yellow Solstice.
Bill
