Tire issue with my B2150
Xplorer
B2150, post hole digger, york rake, brush hog
Apr 14, 2012
New Albany PA.
Hello all. I have a B2150 that has slightly oversized tires that were installed by the previous owner. Current size is 24x8.50-12" front and 13.6x16 rears. All are turf tires and use chains on the front for snow removal. The fronts have been plugged several times and are very dry rotted. The 1 front needs air every time I use the tractor and the other front is almost as bad. Original tire sizes were 6.50x10 front and 12.4x16 rear. Rears are in good shape, but need front tires. Have checked around and found that they discontinued 24x8.5-12's. I'm told that I need to buy new rears and front wheels and tires for many $$$. Anybody know any cheaper solutions? TIA
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
80
Pemberton NJ USA
You can replace the front's with 24x9.50 x12's which are the same height just 1" wider if you can't find the 24x8.50x12"
Roadworthy
L2501 HST
Aug 17, 2019
1,649
525
Benton City, WA
Take into consideration the ratio of the front circumference to the rear circumference. That ratio should be maintained. Changing that ratio can increase wear in the drive mechanism of the tractor.
armylifer
Mar 26, 2013
1,955
696
Thurston County, WA
Check with vendor member millertire. He is very helpful in situations such as yours.
