third function from rear remote
MontanaLogger
M5640su Kubota
May 4, 2021
N.W. Montana
I have a M5640 kubota, that has a two quick connect hydraulic fittings on the back of the tractor. Could I connect the hydraulic lines from a front grapple to these?
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
309
135
Southern Worcester County, MA
Some may say no, but no reason why you cannot. I have seen various YouTube videos of just that. Folks made nice custom length and wrapped hoses to run from front to rear.
Crash277
BX23S
Jan 17, 2021
846
622
Absolutely. A friend down the road has been running a grapple like that on his 50hp tractor for years. He ran fixed lines from the rear remotes up to the loader and then rubber lines on disconnects.
BobInSD
L5740
Jun 23, 2020
360
120
South Dakota
My (used) tractor came that way. I haven't used it yet, but it's very nicely done. Just two more couplers to disconnect when dropping the loader.
ctfjr
L3800HST
Dec 7, 2009
1,686
1,882
central ct
I have a grapple on order and 3 rear remotes. I plan on using 2 for the top n tilt and the third for the grapple. It will be disconnect able in the rear for any other use I might have for it.
BobInSD
L5740
Jun 23, 2020
360
120
South Dakota
It might be slightly more awkward to use (is third function up on the joystick?). One right hand, two separate levers.
MontanaLogger
M5640su Kubota
May 4, 2021
N.W. Montana
I have a M5640 kubota, that has a remote with quick connect hydraulic fittings on the back of the tractor. Could I connect the hydraulic lines from a front grapple to these?
Ok, is the remote valve on the 5640 just, " open or closed?" ie, "on and off?" So, if I plug into the quick connect on my remote, how do I power "open" and "close" on the grapple? What kind of valve between the remote and grapple are others using? thanks.
