The box of parts
7,573
How many relate to this condition?
I have cut off 15 gallon plastic containers 4" tall of lock washers, flat washers, containers of different types and dia of hoses, and on and on to fix mechanical things. Then I have a barn full.
Had 10 rentals at one time and had a hardware store basically to fix whatever whenever. I got stuff!
Hugo Habicht
G1900
Jun 24, 2024
1,533
2,199
Ireland
Well, I keep a lot of things, but not so much broken things unless I know I will need it in the future and that I can repair it.
I am running out of space, so I tend to be more generous with throwing things away.
Nevertheless I keep spare parts for cars that I know wear out and parts for servicing, like filters and fluids, brake pads and disks and shaft seals are always plenty on the shelf. Gear boxes, engines, axles also. Firstly I cannot afford to wait about two weeks for an order to be delivered and secondly any cash in the bank account evaporates at a rate of about 15% per year, despite what the central statistics office is telling me.
5,308
Stuff,, and it may not work where it came from, but it might work on something else
6,277
I have stuff at the shop area at my house (about 1000SF of an 2000SF area dedicated to shop/shelves, etc.). And stuff in the shed (another 1800SF). And stuff in the old shop area at the house that my brother abandoned 25 years ago (2000SF). And stuff in the old shop area at the house my father vacated when he passed away in 2022 (about 500SF of the 2000SF available). So if I’m adding correctly in my head (questionable) that’s 5300SF of storage of all manner of stuff saved by me, stuff my brother left here when he moved including several thousand dollars worth of various electrical wire, and stuff my father had kept. Each area is organized, but there’s no unified organization as it’s been organically compiled based on who all was living on “the compound” at the time.
I have parts for tractors, cars, trucks, and equipment no one has had for years, decades even. I have some weird tools such as a reamer for something or other on a 1956 Plymouth car of some sort. I know the car was brown, had a push button transmission, and my father sold it when I was 3. I’m thoroughly convinced the day after I trash it will be the first day I’ve ever needed it. I have bigger stuff such as a two bottom moldboard plow converted from one point hitch to three point hitch. Last person to use it was me when I was 17. I’m 59 and no one has ever had a use for it at our current place, but I’m sure the day after I get rid of it, I’ll need it.
I have tools at all three shop areas; parts, lumber, and various raw materials everywhere. When I need to work on something, I make a list either in my head or on paper depending on complexity, then make the rounds as needed with either the Mule or pickup (depending on volume of stuff needed) and take it all to whatever shop area is best suited to the job. Afterward, make the rounds again to put everything back where it came from. I know where it all is, but it’s crazy.
At some point in the next year or two we have to decide if we’re staying here or not. If we stay, I really should get some sort of unified organization set up. We threw away some things that were absolute trash after Dad passed. I don’t see throwing anything else away. Never know when we’ll need one of the four perfectly functional washing machines no one uses, two of which I have no idea why they’re here.
PHPaul
Apr 2, 2015
1,261
1,563
Downeast Maine
www.eastovershoe.com
Okay, I lied...
A month or so ago, I agreed to haul off a bunch of scrap for Dale the Builder and some of his minions. Not a game changer, but did put a few shekels in my pocket.
Got a call this morning "I have a load of scrap in the dump truck (tonner) with some interesting stuff, do you want it?"
Sure, why not. At the very least, it's more weight for my next scrap run.
Contents were a pop-up cot, a shipping crate for a lawn tractor and an exercise bike.
The cot was mostly weight. Bed steel is harder than Chinese arithmetic and not worth the effort of cutting up for the angle. It did have a spring suspended canvas "mattress" that I grabbed the canvas off.
The shipping crate is 99% stuff I can use as raw material - angle, square tubing, flat sheet and especially the welded wire cage used for the sides and ends.
The exercise bike is interesting. Uses a Baker Fan front wheel for resistance and has an assortment of bell cranks, sprockets and chains I will salvage for some as-yet undetermined purpose and an "instrument panel" that uses a Hall Effect sensor to monitor RPMS, elapsed time and distance. I'm sure I can find a use for that.
Just call me Fred Sanford. Or maybe Paul Foxx...
:lol:
:lol:
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
565
328
Mandeville Louisiana
Think back prior to building your shop/barn/garage, it was probably just a nice patch of grass, then wham it's overflowing with only "good stuff" with very little room to move around. I always recommend building as large as financially possible, it doesn't matter you'll fill it up in no time, first a hook, then a shelf, cabinets. tables, etc., you know the drill. If there isn't a Pack Rack merit badge, there should be. If you're like me when you finally decide to eliminate some your worldly possessions, you always try to find them a good home. What would we do if we were ever forced to take inventory! LOL
7,573
Don't have any flat surfaces available for a project, they quickly fill with something else!
armylifer
Mar 26, 2013
2,300
1,066
Thurston County, WA
I have stuff from every project that I ever did, or activity that I no longer do for the last 50+ years. I have tried to give away as much of it as I could but since most people don't repair anything these days, it is hard to get rid of it without it going to a landfill. I hate that idea so I just keep it until that obscure project comes up and I find a use for it. There are several times that I have gotten rid of something and a relatively short time later needed that one thing. I can remember at least a half dozen times that actually happened to me in the last 50 years.
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
147
303
NW Arkansas
Distance to availability is directly proportional to amount of stuff I keep.
Organization seems to be inversely proportional to the size available—lots of space, more cluttered and less organized.
Of course then get more stuff and have to organize it better.
When I lived in town (and had a backyard shed, not a shop) I had a lot less stuff and it was way more organized. Now that I am 45 minutes from town I keep a lot more known useful things on hand, AND a lot more organized.
Of course if you think you have way too much stuff either move homes and/or get a divorce. That’s a whole different conversation but a sure fire way to decrease excess…
5,167
I have a friend that “hoards” computers/parts.
He is probably the most “fiscally responsible” person I know (or have ever known), HOWEVER; he simply cannot refuse an “old computer”.
He has an entire basement/garage full of old computers, monitors, CPU’s, Boards, “pieces and parts” for as far as the eye can see.
If you ask him if he has a part (any part), he will walk directly over to it, pick it out and hand it over…..It is kind of amazing really.
I suppose it’s something similar to what the OP posted….Just a “computer version” of it.
I am somewhere approaching “Sanford & Son” status, but not quite that bad…..I still have a hard time throwing “nuts, bolts, and metal scrapes” out though…...
