I did my main drive belt (engine to rear axle hydro) today and replaced the idler pulleys on my T2290KWT lawn tractor and what a bit@h of job to do for a belt replacement. Machine has 65 hours on it and the idler pulley seized causing damage to the belt.
Engine must be removed, steering shaft/gear must be removed and sheet metal must be removed....... This was a five hour job.
TIP! While you have everything apart, REPLACE ALL 3 idler pulleys and order everything in advance so you have it on hand.........You will thank me later!
BTW! Despite this one problem I like the machine.
