I have a MX4800 4x4 with R4 tires that I like for my use around home as they don't tear up the yard or grass strip I mow . The size tires on the MX4800 4x4 are 1200x16.5 on the front and 17.5L-24's on the rear .
I recently just purchased a MX5200 4x4 and it has the standard farm R1 tires . The size of them are 9.5x16 on the front and 14.9x26 on the rear .
Can I swap them out with no problems ? The front tires are about the same size in height with a tape measure , but the rears are quite a bit of difference in height (several inches actually ) .
Are the gear ratio's different on these two tractors since they have different types of tires ?
Just curious what you guys thoughts were on this issue since both are 4x4's and different style tires .
As usual , thanks in advance for your help from allot of you on here !
