Stabilizing When There's No Implement
Modern Otter
L-2201
Jun 11, 2012
Powhatan, VA
Lately I've been using my L-2201 (usually a bush-hogging machine for me) to haul stuff with a toboggan-like device attached to the pin-hitch. I'm getting a lot of nasty tire slap from the right arm of the unused hitch. I don't see a way to adjust the turnbuckles and chains to any effect as long as the arms are swinging free. (Correct me if I'm wrong about that.) Is it typical to use some sort of bar or other device to pull the arms together when running implement-less?
jyoutz
Jan 14, 2019
2,203
1,386
Edgewood, New Mexico
That would work
That would work
jwmoss26
L3901
Dec 23, 2021
W MO
My '21 L3901 came with a bungee on the arms holding them together and off of the tires
kubotafreak
Sep 20, 2018
990
351
Arkansas, US
The telescoping sway links are nice, because the arm is restrained in both directions.
bmblank
Mar 4, 2015
608
248
Cadillac, MI
Yeah, that bungee is a POS. The hooks are just about worthless. Also, there isn't really anywhere to hook it.
I haven't yet, but I want to replace mine somehow. I've got Pat's QH so it'd be cool to put a semi-permanent bungee on there and just adjust the width with the turnbuckles and know that they're not floating around while I try to hitch up.
i7win7
Feb 21, 2020
2,901
3,159
Central, IL
A quick hitch will solve this and make implements easier to hookup
Hkb82
Nov 17, 2021
218
180
Ontario Canada
I used a draw bar for this reason on the old Ford plus adding a few trailer balls to move trailers around.
2,497
Sure there is…. either hook the lift-arm threaded-rods… OR… hook the eye-balls at the end of the lift arms….Or…. get a long enough bungee to wrap all the way-around and hook it to itself (or use two bungees).
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
445
298
E.
mine too.... rubber tarp strap pulling arms together keeping off the tires. each arm had little welded loop for hooks to attach to.
