(SOLD) G2000 4 wheel steer w/bagger and 2 stage snow blower $2300
RangerMan9389
l3540 G5200 G2000
Sep 25, 2025
Southeast Michigan
Hi folks, I have a very nice G2000 gas garden tractor for sale. 4 wheel steer, 60 inch cut, 10 bushel power bagger, 46 inch 2 stage snow blower with the quick attach sub frame and full set of suitcase weight (150# i believe) and the optional REAR PTO. 1215 hours on the meter currently. It has hydraulic deck lift as well as cruise control and the a diverter valve for a 3 point cylinder. I do not have the 3 point for this machine. It did not come with it when I bought it. All fluids have been recently changed. Kubota filters used as well as super UDT2. coolant changed and fresh amsoil in Both gear boxes on the deck. Belts look fantastic. Deck spindles are tight and smooth turning. Greased regularly. Deck is in great shape, no rust holes, pin holes or thin spots. Gear boxes are tight with no play or leaks. Nice cutting machine. I also have a shop service manual to go with it as well as the manuals for the deck, blower and subframe. I also think the original brochure is in there too. Im located in southeast Michigan no far from metro Airport. Feel free to reach out with any questions. Thanks. Asking $2300 20250926_132743.jpg
Hugo Habicht
G1900
Jun 24, 2024
1,501
2,156
Ireland
Would you mind posting a large picture of the PTO lever and the diverter valve lever? I am particularly interested in the labels around them.
Hugo Habicht
G1900
Jun 24, 2024
1,501
2,156
Ireland
Yeah I can do that. Give me a day if you can.
Yes, no problem, no urgency with that, appreciated !
This is a very rare species you have there, with diverter valve, front PTO, rear PTO, front weights and front subframe. And looks in good condition too.
How are the front weights attached? And do you have a work shop manual for the rear PTO too?
If there would not be the minor problem of a puddle of water between us I'd be sitting in the car already towing a trailer :)
Good luck with the sale (y)
RangerMan9389
l3540 G5200 G2000
Sep 25, 2025
Southeast Michigan
I see that is definitely a large puddle. So to be honest I know not much about this rear pto and i do not have any paper work on it. I bought the machine because the snowblower would fit my G5200. But I did not know that the quick attach subframe was different between the two tractors. Who ever originally bought this tractor had the rear 3 point and a G4000 tiller. But the 2nd owner i purchased it from does not know what happened to the 3 point or the tiller he claims. The suitcase weights actually have a bracket that bolts to the rear for using the blower. You have to take it off any time you would use the rear pto. So sadly with the big 60-inch deck to big for my yard and not able to use the blower im am just trying to get what I paid for it back. I am loosing some money because I went through it changing fluids and filters as if I were going to keep it for myself. Ill get those pictures as soon. As I can for you.
Hugo Habicht
G1900
Jun 24, 2024
1,501
2,156
Ireland
Let me know if these are what your after (y)
Yes, brilliant, thank you very much ! :) :) :) :) :) :) :)
And again: good luck with the sale of the tractor !
I personally think your price, considering what comes with it and how it is equipped, is very good.
p.s.: by the way, I think the three point hitch is still available or can be fabricated quite easily.
