Snow plow suggestions needed for L3560
2manybikes
19 L3560 HST with cab.
Aug 2, 2021
12
SW Va.
I'm looking at front mount v-nose snow plows. Our shared driveway is gravel and located in a private community with no contracted snow removal. We are located in SW Va so the driveway has a lot of twists and turns as well as changes in elevation. Snowfall is usually light but drifting can be quite bad. I see "Boss" brand plows around here more than anything else but would like some brand suggestions from those of you who are using v-nose plows now, or have used them in the past. Thanks!
dfixit1
L4240HSTC-3
May 17, 2019
128
United States
Get a pusher if you have the FEL. Went the plow truck with a big V plow and in February I was using the tractor with the FEL to move piles so I could plow more snow. Then got a pusher, worked great until I found a used 72” front blower. Sold the pusher. Plow is better than a shovel, pusher better than a plow, blower best of all. Regards
BAP
Dec 31, 2012
2,007
192
I would go with either a snow pusher or a regular angle plow. V plows are expensive and have extra electronics to run them. Unless you have a lot of snow and/or do a lot of snow removal, they really aren’t worth it.
BX23-S
692
re: I would love to have a blower, but just dont get enough snow to justify the cost.
then bodge your own...
I've got about 500 into my SSQA ,selfpowered,48" unit...most of those coins were for the 14HP engine.
Chanceywd
Kubota L2501 BH77 VIRNIG URG60-CT
Mar 26, 2021
131
56
central ny
Do you have any pictures of yours? I have one from a garden tractor I have thought about powering with a hydraulic motor but a gas engine would be doable too.
thanks in advance if you do,
Bill
jajiu
L3560 HSTC,Grader, Backhoe, Root Grapple, Stump Grapple, Snow Plow, Pallet Forks
Jun 5, 2016
389
62
Rowley, Massachusetts
I have a Quick Attach blade that can be used as a pusher with optional wings and can also be used as a dozer blade by bolting the blade solid. This has been a good replacement for my plow trucks.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
110
39
Central, ME,USA
I don't have any experience with a plow on a tractor, but I have heard that because of the slower speed of a tractor they don't work as well as on a truck. The snow won't roll off the blade at low speeds. I plow a lot of snow with a V-plow on my truck and you do need a little speed to make them work as designed. I can see them not working much better than the bucket at low speed. If I didn't have a snowblower on the front of my tractor I would get a snow pusher sized for the tractor. I think they would work better than a blade and it would be a fraction of the cost.
WFM
L3800
Apr 5, 2013
837
127
Porter Maine
As far a plows for trucks Boss is defiantly the best(my opinion) , you could get a older angle plow and angle and pin the angle you want. Fisher is one made here in Maine for 50 yrs and early on before the angle hydrolics they just pin'd the angle needed. But it could be done with any brand you could find. A few years ago a local guy brought his JD to me and wanted a angle fisher plow added to his tractor. It was an older John Deere with rear hydrolics. Plow was old too. So after fabing a front mount and mounting the joy stick I went to NAPA and got long hydroilc hoses made to hook into his rear hydrolics. Hes run it five or six winters now. Its not fast but pushes all the snow he wants.
Chanceywd
Mar 26, 2021
131
56
central ny
I have a dearborn plow on my 8N that I converted to hydraulic lift and angle. They were mounted and raised with a crude cable mount. I altered the original and made a mount at the transmission it pushes and pivots from. I originally did it with a electric/hydraulic unit I bought I think from northern tool. Worked real well but I added a front pump and made it all hydraulic. It does a good job on my 300' driveway and all around the garage. One thing I did to make it roll snow better was I made a fin for the left edge so when it is heavy or a lot of snow it makes it go to the right better. I got that idea from the one way plows the towns run around here.
Bill
pokey1416
Jun 24, 2020
264
290
SW Michigan
I’ve got a 7’ pusher it works great on straight runs. If you have twists and turns I’m not sure the pusher is the best tool (IMO).
2manybikes
Aug 2, 2021
12
SW Va.
I appreciate everyones comments, photos and suggestions. I'm somewhere between a plow and a pusher. There are multiple driveways on both sides of the road I need to push. The plow seems like a better plan since I can change the blade direction when I get to one. Still pondering!
Crash277
BX23S
Jan 17, 2021
574
434
One think i like about the pusher is you can get the drag top for it so you can get really close to objects and pull the snow away (like garage doors for example). I really want one for my bx but just havent bit the bullet yet to buy one. I've plowed with trucks, atvs, and my tractor. Current set up is a 54" rear blower and a home made connection kit for my FEL with a 60" ATV blade on it. It floats independant of the loader arms and is still a manual pivot. Being ssqa, i can drop the plow and put on the bucket to pile snow out of the way. i get quite a bit of snow up here, some days i would have to plow 2-3x, with having the blower now i don't have to go out as often.
Bmyers
May 27, 2019
1,560
1,135
Southern Illinois
I'm thankful that we don't get enough snow to warrant the investment in snow removal equipment. The bucket, box blade, and straight blade is what we use if we need to move a little snow.
