Sliding barn door track made from over head door
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
342
NY
A93C4163-9DC1-4D9D-A45D-376719F0B005.jpeg E891B10A-2495-43B3-9B27-FB5A56B37752.jpeg 527EF39F-937D-4637-BC67-0428BA38719D.jpeg 3413C53F-9724-45B9-A498-77014ECE8074.jpeg
First pic is of the door hanger, second one is of the track. I put two tracks together and welded them to a piece of angle, spaced apart for the hanger. It was very heavy fortunately my forks could reach. It rolls easy, the door is only 9x9 foot.
Reactions: 6 users
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Nice job! As our economy and society collapse, we all will need to be resourceful and utilize what's available to accomplish tasks.
5,308
Nice job.
Edit: Did you lag screw it, or through bolt it to the header?
5,187
Excellent!
Innovative solutions, born of necessity, are very common in OTHER 3rd world countries, as well.
7,640
Nice! How have you set it up so the door bottom doesn't swing freely with the wind blowing, and how did you design the lock?
I have two 10" x 12" doors on the end of my barn and they both slide outward. At the center there is a concrete pier with two 1" steel pipe sticking up about 1/2", and each door has a 5/8" rod that slides up to release that end of the door. On the outside column each door has a fabricated hook about 8" long to pull them into place. They stay tight no matter what the wind does.
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
342
NY
I am using two 1/4x6 inch screws on each end to lock it temporarily until I figure something better.
pigdoc
G1800S L2500
Aug 19, 2022
401
347
SE Pennsylvania
Oooo, a question for a former pole barn builder!
For the bottom of the door, you can first put another "female" 'track' along its bottom edge, with the opening down. Then, make another "male" track to engage the one on the bottom of the door, shaped like a T. The top part of the T engages the female track on the bottom of the door, and then you weld brackets from the bottom end of the vertical part of the T to stand the door off the proper distance from the sidewall, and with tabs to screw it to the sidewall. Use something stiff for the brackets, like angle iron (not strap iron). You could use strap iron for the top part of the T...
For pairs of doors that meet in the middle of an opening, same idea can work. Just make a short (~6-inch) male track and mount it to the top of a post sunk exactly in the middle of the doorway. [You can probably buy this part ready-made, with tabs to mount it to the top of a 6-inch post.] That way, when the doors are closed, both vertical edges of them are confined against wind. Ideally, the post in the middle is nearly flush with the ground, so you can drive in without worrying about running over it.
When any sliding door is closed, it is essential to have working cam locks mounted on the door posts to hook into the door structure and pull it tight against the door posts.
I've seen sliding doors (lacking cam locks) flipped over and lying face down on top of the roof after a windstorm, many times.
If you haven't built the doors yet, consider making the frame from metal studs. Much lighter than wood, probably cheaper, and you can secure the door siding to them with self-tapping metal screws. However, I would use something heavier than a metal stud for the top horizontal, where the rollers mount. And, box-in the part where the rollers are mounted for even more strength. The hardest part about making doors is making them with perfectly square corners! When you're building them, it's also very important to have the frame blocked up perfectly horizontal as they lay flat on the floor. Any twist you build into them will stay after the siding is on them. That's another advantage of using steel for the frame. Wood warps, and twisted doors are no fun to work with!
-Paul
Guanuwee
UK
I ran a nearly identical setup, and the only snag I hit was keeping the rollers smooth after a few seasons of dust and moisture. I ended up having a tech from https://apolloslidingdoors.com/ clean up the track and swap the rollers, and it saved me a ton of fiddling. If your welded track ever starts feeling crunchy, a quick once-over like that keeps the big door gliding easy.
