Skid Plates for L3400 HST????
Would you want a Belly Skid Plate
  • Unsure
    Votes: 1 20.0%
  • No
    Votes: 2 40.0%
  • Yes
    Votes: 2 40.0%
  • Total voters
  • Poll closed .
Will In Tx
L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Mar 21, 2010
303
Rosharon, TX. USA
Is there such a animal as a under belly skid plate/s?
My dealer said NO.
Do you know how many times trees/mud/etc...crap has been under that vital (sp) part of the motor? I really feel necked!! :eek:
Heavy equipment has like 70/80/100/etc... under belly plate to help with crap not to be there.
So far I could have bought a new skid plate with the $$$$ I shelled out for repairs (note, some done at home by me or my worker).
I feel dam necked under there!!!
I mean I have always been ruff with equipment, kind like boots.
Crap, piss and moan session....sorry:cool:
ptwyz
BX2660, FEL, tiller, disc cultivator, tine cultivator, rear blade, MMM, & more!!
Jan 7, 2010
230
McCutchenville, Ohio, USA
Go to Bro-Tek.com
They have all kinds of protective plates for tractors!
avi8tor
L2800DT, BX2380, RTV X900
Mar 14, 2010
101
Cleveland, Alabama
Here in Alabama, I would probably end up with a lot of debris on top of the skid plate, then have to remove it to clean it off.:D
I think one could be made, although if could get expensive if thick aluminum is used.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Something else to get in the way and slow you down. Especially if you had to make repairs under the tractor. I dont want one for the simple fact you couldent clean between the top of the skid plate and the bottom on the tractor unless you took it off. I dont want any more junk muck filth and dirt on the bottom. More likely to cause something to rust out anyway.
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
Without the mower deck there should be a pretty good amount of clearance down there. I go over some pretty nasty stuff that I need the 4wd with a B series, shouldn't the L should have even more.
Will, are you romping through the Bayou?
Scott
Will In Tx
Mar 21, 2010
303
Rosharon, TX. USA
Scott
Dust..
Yeah the L does have alot of room for plates!!!! Killed my HST line cause of a fist sized tree branch....new replacement $$$$
Does land & wet lands ring a bell.... pressure washer works to clean under, not a problem there.
Did I tell you I like Hooters?
traildust
Jan 27, 2010
1,490
Phelan, California
I have an old cratsman garden tractor I would love to do that to but I don't have the $$$$ for it :(
Will In Tx
Mar 21, 2010
303
Rosharon, TX. USA
Dat be cool beans man!!
I guess I have to get some 1/4 metal sheet and bend or cut.
Oh now we talking bending brake.......dam
Sam427
L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Nov 6, 2009
194
Snellville, Ga. USA
I've had to saw a few tree limbs out that got wedged up under my L3410. Bent some linkages and such, even had a limb wedge into the throttle linkage and push it wide open.
Guess it all depends on what you do with the tractor, mine has seen some serious abuse cleaning up debris behind the loggers, that is a serious mess.
I had a hooter jump on my back one time and leave claw marks!:D
