Sickle bar or disc mower for L3901
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
97
31
Minnesota
I'm looking for a 3 point mounted sickle bar mower or disc mower for use with my L3901 (30 pto hp)
bucktail
Jun 13, 2016
1,299
221
MN
I'd look at the Hp requirements for the disk. You don't say what width you need but I think that the disk mowers take a fair bit of power to run. They're certainly nicer and I've seen them rated up to 12 mph on tractor models and higher on self propelled models. Unless your field is nice and smooth you probably won't be able to run anywhere near what the disk mower is rated for so you may be able to get by with a little less than the manufacturer suggests.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,004
2,372
Western MT
Sickle bars are way more dangerous. I'd go with a disk. I'm assuming you are wanting one for haying. How about a combination to buy one less piece of equipment?
OldcrowP51
Aug 18, 2021
97
31
Minnesota
We own a Wild rice farm in northern MN.
Mostly looking to cut grassed along dikes and ditches surrounding the paddies.
Not much haying so speed not too much a concern.
I do like the idea of vertical cutting with sickle bar for small brush overhanging a trail.
D
Deleted member 47704
Guest
Sickle bar dangerous? They will never throw stuff at 200 mph.
ACDII
Oct 21, 2021
690
432
Illinois
Check out the Ibex disc mowers. They are sized to work with the compact tractors and easier to operate than sickle bars, and less likely to get jammed up or damaged from hidden obstacles.
I believe a TS53 would be the right size for that tractor.
