Should reverse end of HST pedal contact stopper bolt?
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket,
May 4, 2026
41
31
Missouri
As the question asks, should the reverse end of HST pedal contact the stopper bolt? Just realized that mine has about 1.5 inch gap when it stops. Going by dealer tomorrow for another issue and will double check but wanted to see if I could get some quick answers for reference. Thanks.
Caden
1979 B7100
Apr 16, 2026
339
193
Mine does. I assumed that was what it was for, to prevent the internal mechanism from bottoming out.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,199
1,105
Amsterdam, NY
The workshop manual will have the proper adjustment procedure.
The HST neutral position is set first.
Then make sure you have the proper stopper bolt heights set.
Here's an example of the L3901 pedal adjustment, there's no clearance spec (A) for the reverse stopper bolt, only the forward bolt, so I would think it's zero.
Farm Fun
May 4, 2026
41
31
Missouri
Stopped by dealer this morning and talked to service manager about that and needing brake pedals/operation adjusted. Braking not consistent between right & left. Tech had done one adjustment but needs checked again. He will send a tech up to look at it.
