ncridgerunner
BX23, finish mower, bush hog, box scraper, blade scraper, fertilizer spreader
Had something happen that I did not expect today. As I was aerating my lawn I noticed oil spots on the aerator. When I got off the tractor and checked I found the fuel line had ruptured. Evidently this was caused when I was changing from a flail mower to a scrape blade I hung a wrench on the bracket behind the seat. When I raised the 3PH the wrench was caught between the 3PH arm and the rear body of the tractor causing it to bend. At the time I thought it was only body damage but in actuality it pushed the fuel line into a bolt causing a rupture of the fuel line. When my tractor is idling it doesn't leak but when a load is placed on the transmission calling for more power it sprays fuel.
It would be a simple fix if I could easily reach the the connections at each end of the fuel line but they are difficult to access. Anyone else had to replace the fuel line that runs from the fuel tank on the right side of the tractor to a connection on the left side of the tractor? I am thinking about just cutting out the bad area and splicing in a new connection.
