It will run a 7' without any problem.
I believe it would handle a 9' but you would need to be carefull on slopes and in thick grass it will probably try to pull the front of your tractor to the right. Alot of people don't like the 9' mowers anyway because they are more prone to break the cutter bar if you run them on ruff ground.
