Rock Rake
Kickit
Southern, Illinois
I’m surrounded by pine trees which is nice but it’s a chore keeping pine needles and limbs cleaned up...I’m not concerned with the lawn it stays clean but looking for something I could drag around the wooded areas. Has anyone used a rock rake with success to drag leaves, branches, etc?
3,088
I would also like to hear ideas for cleaning up pine needles.
earljr59
L3301fel,forks, gear/shuttle,72"bushhog brand finish mower,60"&72"rotary mowers,
Jan 18, 2019
Fairfield illinois,usa
I have a heavier "Landscape Rake" I use on pine needles and leaves in the fall. It also does a great job on driveways. You can angle it to pull your rock back towards the center of the drive, then pin it straight and smooth it out. I use it a lot more than my box blade or regular blade. If I have road millings or disced up dirt the rake will let me drag chunks and clods into piles. Type in landscape rake and you can see the king kutter brands and others. Rural King and Tractor Supply carry them around here. Or shop used and craigslist.
Jchonline
599
Red Feather Lakes, CO
I like the landscape rake route as well. Lots of other uses.
8,704
Pine straw rake would be the best! ;)
I have a landscape rake and it works pitifully on needles and twigs. :(
bucktail
Jun 13, 2016
1,260
191
MN
Personally I'd leave them be unless I was pining for some seat time. Would chopping them up with a brush mower make things better or worse?
Kickit
Southern, Illinois
Thanks Bucktail...yes that’s what I have been doing for the past several years I was just hoping to find other options especially when the needles cover my drive which is pretty long.
Butlesus
B2150
Jan 28, 2019
Lerna, IL
I have a heavy 72 inch rock rake that works great on cleaning up pine needles as well as working great on my rock driveway shaping it up .
bucktail
Jun 13, 2016
1,260
191
MN
I probably would take them off the driveway. You don't want organic matter in your gravel.
Montana Rick
L2550DT1
Oct 16, 2015
Hamilton
I tried the 3pt rotating wheel design and it was a disaster for pine needles and cones. Finally purchased a 3pt King Kutter Landscape Rake and am quite pleased - the tines are heavier. I maintain 1,100 pine trees on my property and also use the rake for debris/limbs and small rock piling and relocation.
