On my M5091 if you want to set the automatic revs button, the revs slider lever can't be all the way low. It needs to be up at least a little bit forward. Is there any way this can modded so that I can set the rev button with the lever at full low?
At the moment I bush the lever up a mm or 2 and it works ok but sooner or later the lever is bumped and it gets kind of annoying to reset it every time with minimal revs.
