Replacement Drive Belt for Kubota Side Kick XG850
Big Lug
2019 Kubota Side Kick 850-Camo
Oct 4, 2021
Jennings, Louisiana
I am trying to replace my drive belt on my 2019 Kubota Side Kick but am having trouble finding one online. I called the dealer but that was like talking to a dog. I couldn't get much assistance from the guy. Does anyone on here know of a place online that sells the drive belt for the Side Kick?
rbargeron
Jul 6, 2015
1,183
260
western ma
Does Kubota's CVT use the new "universal fit" drive belt? links here and here.
FTG-05
Jul 21, 2013
344
189
TN
K7811-14780
D07000 CVT DRIVEN PULLEY
$288 at the Messicks site.
FTG-05
Jul 21, 2013
344
189
TN
Welcome to Kubota-World!
Tughill Tom
B3200
Dec 23, 2013
1,446
2,086
Turin, NY
So a Drive belt for my Can-am Defender runs $125. I change it every year for peace of mind.
You may have to remove it and take it to an industrial supply house that handles HD Drive belts for blowers and pumps to get matched size.
Big Lug
Oct 4, 2021
Jennings, Louisiana
Tom thank you for replying. I think that is the best thing to do.
5,509
2,220
There are a BUNCH of things to consider when look at replacing the belt with another one. Here's but a few:
overall length
Vee angle
Type of facing
Cord style/type/construction
width
cogged vs non cogged
distance between internal cogs
distance between external cogs
temperature resistance (and airflow that is generated by the belt, if applicable)
All those (and more) are specifically chosen by the manufacturer for the type machinery that the belt will be used on.
I worked on a lot of Kawasaki Mules and Teryxs and ATV's (Prairies/Brute force/etc). What I learned, belt adjustment is critical and so is the OEM belt. Dayco belts never lasted as long as OEM. Neither did SuperAtv belts or Highlifter or any other aftermarket. Secondly they never performed as well as OEM. Aftermarket belts are almost always less expensive but that in itself makes me question where did they cut a cost? Material? Construction? They never tell you that. Yamaha belts vs Dayco, same deal. OEM always outperforms the aftermarket "replacements"-100% of the time.
You might be able to find one but you'll be wise to ask an expert in the field of V- belts to measure and inspect your OE belt and then come up with something for you. Maybe they can, maybe they can't.
And it may not have any bearing on the OP's issue, but I felt it a good time to discuss how the CVT's work on all CVT equipped machines with the exception of Yamaha (and the Teryx 800). When you mash the throttle pedal, the primary clutch closes up onto the belt. It basically pinches it between the two sheaves. If you are in high gear and the wheels ain't moving, or moving very slowly, you are slipping the primary sheaves on the belt. This creates heat. The longer you sit there the more slippage and heat is generated, thus belt and sheave wear. For this reason alone, it is highly advisable to be in LOW gear when under about 10 mph, like, say checking fences, spraying, etc---and also ANYTIME there is a load behind it, such as a trailer, pull behind shredder, etc. These CVT's are nothing like an automatic transmission in a car, you can't just sit there with your foot on the floor with the wheels not turning and expect something to happen at some point. You'll smoke the belt and possibly damage the primary clutch. The Teryx 1000, all of the Kawasaki Mules, their ATV's, Polaris (all), Can-Am, they all use the same basic design. Yamaha (and the kawi teryx 800) both use a wet clutch to drive the primary sheave assembly. In doing this the belt has constant tension and there is no slippage. Yamaha is so confident in their design that they put a real warranty on their drive belts. In 30 years of Yamaha dealings I think I replaced 2 yamaha belts. Also, because of the design of the Yamaha setup, you can actually have GREAT engine breaking, and it's so good that you can push start one. No other manufacturer can lay claim to that. In 2 years of Polaris, I put that many belts on in the first 2 days of working there. But again education in how the system works and then correcting usage mistakes will almost always extend CVT life dramatically regardless of whose system is being used. Little video below to see how the systems work:
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/BX2812APlow/WC-68 Chipper
Sep 24, 2012
403
302
right coast
Great write-up @lugbolt, do you have an opinion on the system used by Arctic Cat? I have an 2002 AC 500i (automatic) and it's running strong still, on it's original belt. Seems bullet-proof! I have used it extensively for snow plowing since it was new, never had an issue (other than broken winch cables).
FTG-05
Jul 21, 2013
344
189
TN
And now it's my turn. :(
Pretty sure my belt went out today while I was out picking up trash. A big bang followed by what sounded like a belt being thrown around. Engine starts and runs fine; no forward/reverse.
How hard is it to replace one of these on the XG850?
