Removing rad from m110x
Dlewie
M110x m9540 m6800
May 20, 2021
Ontario
Hello, have to change out the rad on my m110x. Haven’t had to change rads on any of my kubotas before.... do I have to take out the small frame that holds the oil cooler rad and a/c rad as well to be able to lift it off the top of the rad? Just hoping there’s an easier way than taking all that apart, hoping I missed something simple .
thanks
lugbolt
ZG127S-54
Oct 15, 2015
5,509
2,220
Mid, South, USA
been a long time since I did a 110x but IIRC you have to remove the battery, intercooler, battery tray, then under the battery tray are the screws that hold the radiator support frame to the tractor front frame. Remove those bolts and then anything attached to it (trans cooler, a/c condenser, etc) and then lift it out. Easier if you have the bonnet (hood) off.
