I have a model # L2600DT, serial # 52968, engine L052- K3D with rear tires size 13-6-16 turf, measures center hole 3 7/8' wheel diameter is 17.75 6 bolt hole pattern. The part number from on line is 35040-27850. The wheels are corroded because the calseum used as a counter weight leaked out valve over time causing the rim to corrode. I am looking for two wheels/rims used in good shape or new if price is right.
