Rear remote valve
3,817
I have a rear remote valve on my BX22, which is Kubota part number 70000-02619 that has stopped working. A new one is $312 from Kubota. This is a double acting single lever valve. My question is can this valve be added to or expanded to make it have 2 levers to control 2 cylinders? I have been unable to find any service parts for the valve to rebuild it.
As a side note, I learned the expensive way, that the failure of this valve is what caused my 3 point hitch to stop working.
The original kit was a BX7322.
If what I want to do isn't possible with this valve, can you recommend a valve for my application? thanks
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
334
Alberta
I'm not sure on the BX, but I just ordered a single remote for my MX, to replace an existing homemade set up that the previous owner installed. They gave me the option of single, dual or triple remotes. So I would assume you should be able to get the same for a BX.
