REAR BLADE
kcs
Kubota B2650
Jan 9, 2021
149
I’m
Looking at getting a rear blade for my B2650. Land Pride is $610. I found a Titian for $420. Are Titian a good company?
old and tired
L2800 HST; 2005; R4
You mean Titan? It's a more economical company - I have not heard many complains on this website...
What models are you looking at? Heavier is better...
RB1560 is better than RB0560 at 100 pounds heavier @ 248#...
The Titan 1405 is 180 pounds...
kcs
Kubota B2650
Jan 9, 2021
149
Would my B2650 pull the RB1560 ok? That would t be too heavy would it ?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,377
1,648
Kalamazoo, MI
Heavier is not always better...depends on the intended use. For building roads or irrigation ditches, heavier is better. For fine work and snow removal, lighter is better. I can make my light blade dig like a dozer or skim like a butter knife by adjusting the top link accordingly.
kcs
Kubota B2650
Jan 9, 2021
149
What tires do you have? ...And do you have them loaded with fluid? Ag/R1 is best for traction; Industrial/R4 would be 2nd best... Turfs might be iffy.
What are you planning to use the blade for?
I have R4 and yea they are loaded
trueg50
60
77
Vermont
Snow removal. What little bit of snow we get in Va. and maybe some grading. I’ve got a box blade for any fine grading
You'll want something like the RB1672 then. The 72" is required so you can angle it and still cover your tracks.
I use an RB1672 on my B2601 and had good luck with it last winter.
i7win7
Feb 21, 2020
3,168
3,626
Central, IL
Using RB 3584 on my B2650
OrangeKrush
Nov 15, 2020
1,047
514
Indy
Yes you'll want something larger for your tractor, I have the 1560 on my BX2680 and is perfect for it. As said above when angled you want to cover the width of your tractor.
