R14 tire pressures
GSD-Keegan
B2601 with Fel and Bh70 backhoe
Mar 6, 2021
542
704
Ontario, Canada
Interested cuz I have exact same tractor and tire combo! I also searched the manual and on line for pressures with no luck.
2,364
The B2601 manual only lists tires by size, not type.
What are inflation pressures for my R14s?
I think the tire sidewall will tell you the acceptable range of tire pressures. If just the max pressure is listed, I would probably start at the mid point.
R14 tires have been referred to as "balloon like" if I remember correctly. I think you will need to pick a pressure and see how it performs for your needs.
Mossy dell
B2601 (2021) JD970 (1998) B2100 (1991) B6100E (1988)
Jul 20, 2020
274
125
sw VA
20 lbs all around, according to my salesman. This aligned pretty well with the chart in my manual.
RalphVa
738
319
Charlottesville
Will see what they're at when I finally get around to checking them. Think I'll keep fronts up and maybe put rears at 20 psi for better ride. Saw an R14 post on TBN that showed some going down into the teens in rear pressure on R14s, for ride quality.
3,833
If your rears are filled, you run the risk of blowing the tires off of the rims because of lower pressure.
