question on releif valves
bigjerr
b7800 b6100 b670
May 3, 2015
calif.
hello I have an older kabota b670 bh that has a squealing relief valve , ive read that these can be shimmed to increase spring tension to bring pressure back up , this is an older backhoe an has the hexagon shaped valve , safe to assume just fit a socket to it and back-it out and add shimm as needed ?
don't have a gauge to check pressure but its for shure needs shimming as its gets worse the more it squeals
thanks for advise Jerr
8,702
Sounds like it needs serviced more than it needs just shimmed. ;)
