Pistols and rifles and threading barrels.......ohhh my!!!!!
Yooper
3901 LA525
May 31, 2015
1,761
939
NE Wisconsin
I prefer a radius thread relief so I don’t create a stress riser, or put more plainly, a place for a crack to start. But to answer your question, you can create the thread relief with anything. If using a parting tool for instance, slow the speed way down to prevent chatter.
As far as threading your pistol, my way of doing it is to run a live center in the bore, thread the barrel and then recrown the barrel afterwards centering the bore using a grizzly rod.
I have tried several different methods of centering the bore and this is way I prefer. I crown barrels at 11 degrees. And doing this almost always makes a pistol or rifle shoot better because the factory crowns are inconsistent.
And keep in mind the old saying: Ask three machinists how to do something and you will get four answers 🤷‍♂️
ken erickson
Nov 21, 2010
1,455
2,749
Waupaca Wisconsin
As a side note.
Back in the day when threading shotgun barrels for internal choke tubes was big business, before the shotgun manufactures started selling barrels with choke tubes , we did hundreds of retrofits on fixed choke barrels.
It was amazing and very evident with the naked eye just how far off some bores/chokes was to the OD of the barrel ! Once the choke was reamed out, or barrel shortened and the piloted tap reaming was done, more than one barrel was deemed not safe due to a un-concentric bore leaving a thin wall thickness.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,247
1,877
Pittsburgh
This guy looks like he's been lurking around the liquor cabinet:
He shall be known as "Winky".
5,648
Yes sir!!!!
Every time I start a project I forget about this "machinist phenomena".
After researching a little bit, I am seeing that there are many ways to do this, which leads me to my next problem....deciding on which way to go.
The first thing I want to do is to practice though. I would really like to be comfortable with the speed/feed/cutter choices BEFORE cutting into my barrel.
My current "inventory" consists of primarily "mystery metal" so I want to purchase some "known bar stock" to practice with.
Does anyone know what metal type would be best to practice with?
5,648
Just a little comedy for the day.....Now where did I put my tap and die kit ;) :unsure::ROFLMAO::cry:
EDIT:
Found a better one during my search.... (y) :p
The "chair vise" is a classic...... :ROFLMAO: :ROFLMAO: :ROFLMAO: 🤫 🤫
Yooper
3901 LA525
May 31, 2015
1,761
939
NE Wisconsin
4140 is common for steel barrels and 416 is common for stainless barrels that are advertised as such. McMaster stocks both. I agree with you about the practice part especially if you haven’t done a lot of single point threading.
Two gunsmiths I know use range rods to set up their barrels. I tried that method but when I removed the rod and reinserted it after getting it just so, it didn’t repeat the results. In fact it wasn’t even close. When I told this to one of them he got a real ‘deer in the headlights look’ basically telling me he had never tried to repeat the process. But his rifles shoot very well so maybe we are all overthinking it.
Whatever method you choose will probably be fine. Good luck!
lynnmor
B2601-1
May 3, 2021
1,829
1,626
Red Lion
4140 steel is available in annealed and heat treated. It machines rather well up to 44 Rockwell C. You should test the hardness of the part you are wanting to thread, then get a sample piece of steel about the same hardness. Some gun parts might be hardened only on the surface.
5,648
I don't have the capability of "hardness testing", so I will run up to the local ALRO metals and grab a couple of bars of 4140 to play around with.
Yooper
3901 LA525
May 31, 2015
1,761
939
NE Wisconsin
EDIT:
You are absolutely right! This one is better (worse) than the first one. Chair vise, disassembled way more than he had to, and he forgot to mention his secret trick. You must perform this task barefoot.😂
#40Fan
685
504
After checking prices of the threaded barrels that are available that still retain the front site, I'd not waste my time on this one.
5,648
Go to ebay and buy some cheap barrels. Even better if they fit a rifle you own.
Good idea. (y) (y)
I'll look around for some.
Yes sir, I agree that "technically" it's not really worth it from a money standpoint.
However, it is an "adventure" for me.
I often do things that make no sense financially, but I get a great deal of satisfaction by "doing things".
Heres an old Proverb I tend to live by..........."Why buy something for 200 dollars, when you can buy a machine for $2,000 and make it yourself";):ROFLMAO::unsure:
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
899
1,699
Baranduda, Victoria, Australia
Sounds good to me.
I just read your proverb out to my wife (she knows you pretty well from posts of yours I read out to her). Her response...."well then you can make it multiple times". I think she's as bad (good??) as us.
#40Fan
685
504
I understand, because I'm the same way. I'd still buy the barrel to start playing with your pew pew now, though.
As for sayings.....
Why pay someone else to F it up, when I can F it up for free?
3,597
My favorite machining related saying:
"Precision is an attitude, not a skill."
