PennOhio: Tractor/Mower/Trailer Combo - $16,995
Daddy Stew
B7800HSD/F
Apr 6, 2015
Transfer, PA
Separate Pricing Options Below
2007 Kubota B7800HSD-F Compact Tractor
  • 137+ Hours 30HP, 4-cyl diesel
  • 4WD Hydrostatic Automatic
  • Rear 3pt. Power Take-Off (PTO)
  • Mid PTO
  • R4 Tires front & rear
  • Two-post ROPS
  • 60" Front End Loader (FEL #LA402)
  • Oil & Filters included for next Maintenance Cycle
  • Will deliver 50 miles from Hermitage PA
UPGRADES
  • Piranha Tooth Bar
  • Pat's easy change System
  • Hodge Stabilizer Bars
  • RhinoHide Canopy
  • Tire Chains - all 4 tires
  • Bolt-On Hooks
  • Bolt-On Front 2" Receiver
  • Rear Tool Rack for long handle and chainsaw
  • Chain Box
  • Side View Mirrors
  • RimGuard Loaded Tires
  • APPROXIMATE WEIGHTS
  • Tractor: 1741 lbs.
  • RimGuard (can be drained out)
  • Front Tires: 130 lbs. each
  • Rear Tires: 300 lbs. each
  • LA402 FEL: 617 lbs.
16 ft. Heavy-duty Trailer
  • PA Title, Current Registration & Safety Inspection
  • Four (4) NEW Tires
  • NEW Brake Controller w/onboard Battery
  • Folding Load Ramps
  • 2-5/16" Ball
  • Dual Axle
  • NEW Electric Brakes
  • GVWR: 10,000 lbs.
  • NEW LED Clearance Lights
  • NEW Transport Chains
  • NEW Chain-Ratchet Binders
  • DIMENSIONS
  • Inside Fenders 78-1/4"
  • Outside Fenders 98-1/4"
IM502 60" Bush Hog
  • Fits Standard 3 Point Category 1 Hitch
  • 2" Slipclutch
  • NEW Driveshaft
  • WEIGHT: 585 lbs.
  • Kubota Tractor: $14,500
  • 16ft. 10K Trailer: $2,500
  • 60 inch Bush Hog: $695
