Over the tire treads
Pony Doc
SSV75 Kioti LK3054 Oliver 1250
Dec 15, 2020
32
Central Colorado
My SSV75 skid steer is mostly used with a bale handler on a hard surfaces, it works great in that application. I'd like to put it to other uses but the R4 tires and skid function are hard on turf and pastures. I'm considering over the tire treads to decrease wear and tear on the grass. Any advice and experiences would be appreciated.
bucktail
Jun 13, 2016
1,233
177
MN
From what I've seen the tracks will tear up the lawn unless you aren't going to turn.
i7win7
Feb 21, 2020
3,214
3,718
Central, IL
It just requires practice, 2 wheels won't tear up lawn
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,123
931
Williamstown Ontario Canada
A friend installed rubber tracks over his skid steer wheels to reduce ground pressure. He was doing landscaping work.
He found in wet muddy conditions the rubber tires would spin inside the tracks leaving him stuck.
Dave
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
304
98
Nicollet, mn
The trick on sod is long wide turns, or a back and forth slow turn. Go out to a gravel area and practice. Or when possible drive into the grass and back out, no turns. Anyone can rip up the yard, the better operator can make it look like he was never there. When it is soft stay out.
Pony Doc
Dec 15, 2020
32
Central Colorado
Appreciate everyone's response. Apparently another option is switching to a turf tire like the Mighty Mow
