Oil Seal Replacement FL850 Tiller
KCOrange
B7100, B6100, FL850 Tiller
May 14, 2022
Mildura Australia
When replacing the bearings and seals on our FL850 Tiller, The bearing pushes the seal out of the housing when it is fitted. [genuine Kubota parts]. Advice appreciated
Andy
1,260
Not enough info. Is the bore of the seal-area worn oversized? Are the bearings the correct part numbers? Did you install them in the proper orientation? Do you have pictures?
Are you asking about bearings in the gearbox? or the Chain Case…?? Did you forget to install the Cir-clips?
