non OEM hydraulic rear remote for 2009 M7040?
sflight
2009 Kubota M7040
Sep 12, 2010
Fife Lake, MI
Looking to stack 2 more rear hydraulic remotes to the one I already have. Does anyone know if there is an aftermarket valve that I can stack? Old Kubota part # is 907. I understand its been changed to part #3C081-82542. I was quoted $1374 for one Kubota stackable hydraulic remote valve. Getting 2 valves and the lever kits from Kubota is getting unreasonably expensive. Any info would be greatly appreciated. Thanks
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,124
931
Williamstown Ontario Canada
With the right skills, there is nothing stopping you from putting a double spool control valve with a power beyond feature in the line from the loader valve's power beyond line. From this valve you supply two rear remotes.
Do something wrong however and damage the pump then you will learn what expensive really is. It will never look like a neat installation.
Dave
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
I would see if I could find a junked tractor with the needed parts for sale. There are salvage companies out there.
4,835
1,588
Yeah so what you'll do is run down to the local college, latch onto a mechanical, then hydraulic engineering class, then after you have that done, take a machine tools class and then build/market you own aftermarket valve kit.
They are not just simple devices like many think.
Kubota valves work on Kubota tractors and they just fit. Real easy to put on. They are expensive, but that M7040 isn't necessarily a cheap tractor either. I'm fairly sure that the investment you make now for OEM stuff is going to pay for itself come time to trade up, or sell. Aftermarket stuff is generally not even close in comparison. I do this stuff on a daily basis and it is VERY VERY rare for any aftermarket part to fit and work exactly like OEM; even sometimes the aftermarket company that is owned by the OEM. To my knowledge there is no aftermarket rear remote but I'm gonna watch this thread to see if maybe someone else knows if there is.
MtnViewRanch
719
176
Lakeside Ca.
Install a couple of diverters bolted on top of the existing valve and still use the existing control lever. Relatively simple, still about $900 though.
