NEW STARTER but old wiring harness
OLD GAR
MF210, FORD 8N, BIG TEX CH18,
Aug 3, 2015
69
ZWOLLE
Just put on a new starter that another had removed. No response when key is turned Is there a wiring diagram where I could determine the location of the wiring for the starter? It is a B7500
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
Wiring for a B7500 or any manual for that model seems impossible to find.
The B7510 is the next model and I have attached its wiring diagram. You will have to decide if it represents what you have in any way.
You need to work your way through the many safety switches, seat, clutch, pto....as each could prevent cranking and thus starting.
Dave
OLD GAR
Aug 3, 2015
69
ZWOLLE
Thanks Dave, You are correct in that there is a dearth of specific info on the B7500 systems. BUT! what you linked me to, was a real help. Tracing wires isn't my cup of tea but seeing the direct line from the starter to the clutch safety switch did the trick. That switch had been accidentally moved when there was other work on the chassis and belly mower adjustment. Why it wasn't in the proper location who knows! Thanks again for the help.
