New BX control stick return-to-center function
PaulR
Aug 3, 2020
581
457
Hadley, MA
Newbie operator, new BX 23S, 35 hours.
I just had the dealer install 3rd function valve, new/different control stick, new button on stick.
For my first 34 hours I seem to remember the original stick would return to center quite well, neutral position, unless I jammed it forward for floating.
Now with this new stick its seems quite a lot stiffer, and while running my sweeper for a few hours last night it was either staying up or down when I moved it, I'd have to pull/push it back to center. Doesn't seem right. Thoughts/opinions. TY.
je1279
LX2610 w/ 60" MMM, LP 72" Snow Plow, EA Wicked 55" Grapple, and Woods 60" BB
Dec 6, 2020
723
454
Upstate NY
Short of moving it past the float detent as you mentioned, the loader control should return to center on its own after you release it.
ken erickson
Nov 21, 2010
998
1,551
Waupaca Wisconsin
I have a L2501 and with about 30 hours of bucket grapple work the loader control stick would not return to a neutral position. I had to nudge it into position. With mine it was the linkage underneath the plastic cover that needed lube. Not sure if yours uses external linkage like mine but its a thought.
Crash277
BX23S
Jan 17, 2021
846
622
They likely didn’t replace the loader stick, they swap out the top of it and then run the wires Beside it, or in some cases online I saw people putting the wires through the center of the stick. These are the buttons on mine.
je1279
Dec 6, 2020
723
454
Upstate NY
On my LX2610 I did replace the entire control for the Kubota OEM 3rd function kit but I'm not sure if it's the same on the BX's or not. There were two bolts that hold the control to the assembly underneath the seat.
