New B2601 cutting deck
JimmyJazz
1,098
644
Pittsburgh, Pa
Hello , I have now mowed my yard 3 times with my new tractor and have a question. When I am backing up say over a 30 ft area is the mower designed to cut as well then as when moving forward ? Initially it looks good but upon closer inspection the whole job looks kind of inconsistent in height/cut quality. Thanks.
Fordtech86
L3200
Aug 7, 2018
4,790
5,623
Pineville,LA
Somebody here can likely give you the reason as to why, but I will say my zero turn is the same way. I believe I know why but....
imnukensc
BX2380
Sep 10, 2015
619
512
Midlands of SC
No, it won't look as good. When backing up the first thing to hit the grass is the upturned parts of the mower blades which bends the grass over and tears it instead of cutting it. When mowing forward the first thing hitting the grass is the sharpened part of the mower blades.
JimmyJazz
1,098
644
Pittsburgh, Pa
I Kind of of figured that. I just "retired" my aging Steiner tractor and I had never noticed much of a difference.
2,365
It might have something to do with the level of the mower deck.
In theory (mine only, don't know what the reality is) if the mower deck is perfectly level, it should cut the same in either direction. BUT if say the front is lower slightly with respect to the back, then the cut would be different forward VS backwards.
Solution? Cut only in one direction! LOL. I never claimed to be more than a simpleton!
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
231
80
S.E. TN
I find the wide rear tires lays the grass over before the deck can cut it. kind of like the fronts do going forward only worse.
i‘d like a front mount ground following deck on mine. I can’t use a zero turn, but I like front mounted decks way better.
