M7060 ROPS - Tow Light Connector
bc1962
M7060HD ROPS / M4-071D / M6800 ROPS / RC2512 / ZD1211
Nov 23, 2015
21
Walnut Grove, AL
Can anyone tell me what type of implement/towing electrical connector comes on the M7060 ROPS? It's a flip up round keyed connector with 7 pins. Mine says "NANABOSHI", but searching for that is useless. Is this what is call a SAE J560?
I have found nothing at TS or any hardware store. I am wanting to outfit our older Kubota Tractor M6800 CAB with the same type of connector. Our Vermeer bailer appears to use this for its road lights.
Thank you,
Bill
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
329
94
Bagley, MN, United States
bc1962
Nov 23, 2015
21
Walnut Grove, AL
That is exactly what I was looking for! Thank you! Great prices too.
I purchased the Item # PK11700 to plug into my M9540 and I see that in the specs for that plug as well as the jack Item # PK11720 it indicates that - meets and exceeds all standards of SAE J560. I could not find the specs to confirm that with the plug with the spring cable relief Item # PK11702 but it appears to be the same plug.
https://www.etrailer.com/Wiring/Pollak/PK11700.html
https://www.etrailer.com/Wiring/Pollak/PK11720.html
https://www.etrailer.com/Wiring/Pollak/PK11702.html
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
About a year ago there was a discussion about that very plug and the features it offered.
What I learned was that, although my WSM showed brake lights, in reality this is a feature that depends upon regulations in a particular country and I did NOT have brake light wiring nor even a brake light switch
Depending upon how you hope to use this plug, suggest you check it out to see that what you want is available.
Dave
