M7040 remote valves
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,042
Williamstown Ontario Canada
I am awaiting delivery of a new M7040 with cab and loader. I asked dealer to install a second remote valve.
Will each of the remote valves control a double acting hydraulic cylinder or will I have to provide an additional valve to control the cylinder?
I have one cylinder rotating the chute on my snow blower and a second cylinder raising and lowering a blade for pulling snow away from doors.
Thanks for any advice.
Dave p
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
The rear remotes are double acting. If your snow blower is on the rear it should work fine.
Not sure about the front but can't imagine that it is not double acting as well. There is really little use for a single acting hydraulic remote.
I'd recommend getting the third rear remote since the tractor is being worked on anyway. Along with a Top & Tilt you can also run a hydraulic cylinder for another function (like rippers on a box blade).
TripleR
Sep 16, 2011
1,911
SE Missouri
What GWD said, I have two on our M8540, but when I got our L5740 had three sets with Top and Tilt as I have a box blade with hydraulic rippers. I didn't get any with the float function, but would if I did it again I would get at least one.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,042
I was at the Kubota dealer to arrange for remote valves before he delivers the tractor on Friday. Remote valves are expensive. $860 for the second one with float. I could not afford a third at this time.
Dave p
TripleR
Sep 16, 2011
1,911
SE Missouri
Dave p
I can sure understand that. I didn't pay that much for those on my L5740, but I had it priced configured with the OEM TnT and one extra, also bought some equipment, so I got a break or so it seemed. Our M8540 came stock with two rear remotes and I don't see me getting a third for it.
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
When I got my M7040 I had all three put on when they made the tractor. I think then it was $600.00 when being built. I use them all. I have had JD's with 6 valves. You can never have to many.
David Pidgeon
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
Dave p
There is a pair of valves that'd fit a 7040 on ebay at the moment, he had 4, I just bought 2. #M7610 same part as my dealer sells for a fair bit less.
