M7040 HDNBC Stuck in 4wd
Alf Roberts
ON
Hi All,
This tractor is the hydraulic shuttle narrow body cab and does not have a mechanical handle to turn on the 4wd. There is a button on the dash that seems to control the 4wd and some kind of steering feature. The 4wd icon remains lit and it mechanically 4wd is locked in. I have gone forewords, backwards, and raised the front wheels. The tractor was bought used this spring and has sat all summer, as it was bought to run a snow blower. By the wear on the tires, I am guessing 4wd has been on for quite some time. Is there a solenoid or a fuse I should be checking? Any other suggestions? Most of what I find online insists there is a mechanical handle.
7,487
Hi All,
I would suggest you start by reading the Operator's and Workshop manuals. Both available free from Kubotabooks.com.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
261
91
NE Wyoming
I believe 4wd is applied when braking also, so another possibility is a stuck brake switch or a brake pedal that doesn't return all the way.
