2019 Kubota M6060 for sale with 654 hours. Comes with LA1154 loader and a heavy duty round back material bucket. Loader is adjustable for either height or lift power depending on application. Loader has bucket level indicator. Pins are tight and greased regularly. R1 tires. 4 wheel drive and differential lock. Has vertical exhaust and will fit under 8' shop door with the roll bar down. Second owner. Everything works as it should.
- LA1154 loader with heavy duty round back material bucket (skid steer quick attach)
- 8 forward/8 reverse speed shuttle shift transmission with hydraulic power reverser. 4 high and 4 low in both forward and reverse
- Deluxe class II 3 point hitch (extendable link ends and slides)
- Draft control for field applications
- One set of rear remotes
- Bucket level indicator
- Adjustable width front and rear wheels
- Tilt steering
- Trailer plug for brakes/lights
- Does have small dent on hood and left rear fender
- Fresh engine oil change
Can deliver within 3 hours of Leonard, Michigan.
- Tilt steering
