M5660 Hour Meter
4,049
easy ?
remove from tractor,sit on bench, power it up, apply appropriate signal to the 'engine is running' input lead of the meter.
would need to see wiring diagram to figure out WHAT that signal is.
another option, if meter has CANbus interface(actually ANY communications interface) , access the 'hours' register and rewrite whatever time you want in it.
both of these are 'easy' for me....
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,382
1,649
Kalamazoo, MI
Probably put 12 volts on the correct terminals and it might start counting. Might need a circuit diagram to find the correct points.
4,049
If M5660 is the tractor ( and not the hour meter designation..) that unit has a 'fancy' dash where the 'hour meter' displays lots of 'stuff' but providing you get a wiring diagram for it ( in WSM ??) it's easy to change the hours.
4,187
easy ?
Very easy for all of us too! :ROFLMAO:
L4701, T2290, WC68, grapple, BB1572 box scrape, Howes 500, 16kW IMD gen, WG24
3,610
Just curious, why would you want to increase the hours on the meter without the engine running (unless the meter was replaced)?
Almond47
I ordered a WSM today to hopefully get a wiring diagram. Thanks for all the great input and any more. My farm size has decreased and i have to meet a total hour obligation . I would like to do this with out burning over priced diesel.
