Hi all, new user/tractor owner here! Have a Kubota M5400 SU up in Maine.
Last year while bush hogging we got stuck on a boulder - which at the time I thought broke the propeller shaft, disabling our 4WD. Finally got around to taking a look and it was actually the pinion shaft that broke right at the front axle casing.
I pulled the casing off and I’ve been removing the various clips and collars around the broken shaft. Now I’m stuck trying to get this bearing out (picture below). I’ve tried a gear puller and slide hammer but in both cases no arrangement of the “fingers” can fit around the bearing to pull it...what are my options here to pull this out?
My hope is I can pull the broken pinion shaft out and replace it without having to pull apart the whole front axle to do so / replace the gear as well. If it isn’t obvious I am 1) very new to tractors and 2) very new to any kind of mechanical repairs...thanks!
