M120 with LA1601 loader, loader not working
LOS
South Texas
So I'm trying to help my neighbor out with this tractor. he inherited it from his father in law. tractor was not running and the hydraulic pump was missing off it. honestly that's about all that is known.
some wiring repair and a new battery got it running. we installed a used (but known good) hydraulic pump, new filters and new fluid and fired it up. the tractor moves, power steering works, 3-point works and rear remotes work. however the loader was acting very erratic when you tried to raise it might go up or it might go down but would immediately stop and the hoses would jump and the motor would bog down. it acted like it was pressuring both sides of the cylinders at the same time.
long story short I rebuilt the loader control valve. I did find a blown O ring and the spool caps and detents were pretty rusty inside.
the spools moved freely and there was no scarring or anything, I installed all new O rings, new detent kits and new spool cap kits all bought from Kubota. everything went together without issue and I'm 99.9% confident I assembled everything correctly.
After reinstalling the control valve the loader is still not working correct. It has 2 different issues that I can identify.
1st when attempting to move the bucket in either direction the engine almost stalls and hear the pump like if it is dead headed and the bucket does not move at all, this issue was there before and after rebuild.
(when i loosen the lines at the cylinders only a little fluid comes out and the symptom is the same.)
2nd when trying to raise the boom if you pull back on the control lever 3\4 or less, the bucket will drop.
but if you pull it back all the way with mild force it will go up for a little ways then slow to a stop.
(if I loosen the opposite line on the cylinder the boom goes up normally)
I did not replace the relief valves on the loader control valve, they are a bit pricy and I'm not sure they would cause either issue.
I feel like I am missing something simple but I am at a loss, any help would be greatly appreciated.
5,911
You are indeed missing something simple and the control valve is the last thing to attack. You most likely have a flow restriction somewhere in the return circuit for the loader. This os a common issue with Kubota loader hydraulics. Common causes are bad quock conmects, improper plumbing, improperly adjusted 3pt feedback.
Since the remotes work amd the loadercwill operate when you remove the hose from the cylinder I woild suspect the quick coupler on the loader is not working.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,495
2,087
WestTn/NoMs
Check that the lines from the tractor to the loader valve are not crossed, specifically 010 and 020.
LOS
South Texas
Thanks for the reply Dan I was told the same thing by a heavy equipment mechanic I happened to run into. we ordered new quick connects for it.
LOS
South Texas
Funny you posted that picture I had just come across it yesterday. 10 and 20 are not crossed but 10 and 30 are crossed but they were that way before I took it apart. I know because I took pictures before taking it apart. I am going to switch them to where they are supposed to be but how much difference would it actually make?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,495
2,087
WestTn/NoMs
I predict it'll solve some of the problem :)
5,911
Now I am confused. I believe 10 and 30 are tank return and power beyond. Switching them would not affect the loader but the 3pt and remotes would not work ???
2,464
@TheOldHokie
I am assuming that you are assuming the FEL valve is the original part.
If the valve was replaced with some “incorrect“ valve would there be some reason to swap 10 and 30?
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
219
47
Dickson, TN
Where are you getting the hydraulic supply/return for the loader valve(s)? If from the remotes on the back of the tractor the first thing I would do is test/replace the quick disconnects and make certain the poppets inside the quick disconnect are opening.
Some Kubota remote valves have a closed center position. This is particularly common on larter M series tractors.
5,911
See parts diagram earlier in thread. Open center system and loader valve with tank return and power beyond supplied by implement pump.
LOS
South Texas
Yes this is correct and loader valve is original. unless I'm mistaken 10 and 30 are the pressure and power beyond circuits. someone had changed the power beyond hose and fitting making it impossible to switch it with the pressure line. we ordered the correct hose and fitting. just waiting on parts to come in
5,911
Just looking at the parts deawing 10 looks like tank return to me and.20 is power beyond.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,495
2,087
WestTn/NoMs
My vote is
010 Power beyond
020 Pressure
030 Tank
I could be backwards on 010 and 020, you could fire it up for a sec and make sure fluid comes out of 020. Or trace it back to the pump.
5,911
My vote is
010 Power beyond
020 Pressure
030 Tank
20 and 30 are both going to what looks like an aux outlet block in the pump pressure line.. That would be P and PB in some order. 10 looks like it is dumping into the case - E.G tank.
In anycevent the plumbing needs to match that drawing.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,495
2,087
WestTn/NoMs
LOL, we must be looking at different pictures.
5,911
Funny you should say that.
Thw joystick linkage on my LA525 loader broke weeks ago and I ordered parts from Messicks. Nothing I got in two auccesdive orders was right.
Talked to but the parts depsrtment about the serial number break their webpage showed. They insisted the parts were what was listed for my loader. In frustrarion I went to Kubotas page and low and behold - no serial number break and the pictured part matches my loader. I am out about $200 in parts and shipping asca result.
LOS
South Texas
Soooo sorry I just realized I mis-read the diagram it is 10 and 20 that are switched
030 just dumps into the top of the case in the rear of the tractor so I assume it has to be tank return. from what I have been able to find in the service info the port in the front of the block ( 050 in the diagram) is pump pressure and the other port in that block is power beyond and those are the 2 lines that are switched. 10 and 20 sorry again my bad.
LOS
South Texas
010 = power beyond
020 = pressure
030 = return
according to service info this is correct, and currently 10 and 20 are switched
