LX 3310 - Fording through Deep Water
AllPawDrive
Aroostook County, Maine
Hello all,
I noticed today that my front axle has a curved vent. My tractor was parked at an angle and I noticed a little bit of fluid leaking out the vent.…not much.
It got me to wondering, if i ran through deep enough water, could I end up getting water entering the front axle through the axle vent? Should I plug the front axle vent when going through deep water?
Thanks.
2,164
My first thought would be yes - unless that vent has some one way pressure valve at the beginning of it.
As for plugging - I would suggest adding "hose" to make the vent taller ......... much like those JEEP guys with the air intake when crossing rivers and whatnot.
radas
Mar 21, 2022
721
831
Hose and check valve like 85Hokie mentioned will solve your problem. Google search for differential vent check valve, grab a length of hose, barb fitting, hose clamps, and a couple zip ties and you can extend your breather tube. Alternatively, if you can remove the breather tube and clamp a new vacuum hose on altogether, that will eliminate the need for a hose barb and give you a cleaner install.
SDT
multiple and various
Apr 15, 2018
3,084
924
SE, IN
Hello all,
Thanks.
Absolutely.
Cold water contacting warm/hot axle creating a vacuum to pull water in if vent below water level.
3,012
Deep water (which I define as above the front axle wheel lug-bolts at their LOWER points) is BAD JUJU for your tractor. The front axle isn’t the only concern…. it’s the transmission, clutch, HST, PTO, and differentials which can be expen$ive. Stay out of deep water unless you have deep pockets.
